Blown 944 Hybrid Stroker DIY Guide
Old 01-29-2014, 04:57 PM
  #31
ilikemy944
Going with the pack
is quite monotonous.
ilikemy944's Avatar
How deep is your new 'floor' ? I am curious to compare that to the depth of the 3.0 block.
Are you using straight liners or do they have a flange/shoulder/whatever?
Old 01-29-2014, 05:16 PM
  #32
refresh951
refresh951's Avatar
Originally Posted by blown 944
Shawn, you're doing a wonderful job with this write up. Thank you again.
A couple of things of note;
Crank grinder should be able to keep the crank straight if they are cautious when grinding each journal. It is imperative that they watch the runout as they are machining.
Regarding the radius at the big end; we used to have cranks ground with a "fat radius" and used narrow race bearings on small block chevys. Same idea here.
Rods need all ends machined for pins.
If any aluminum makes contact at the bottom of the cylinder, the skirt will gall and ruin the cylinders.
May want to add the option of using flanged sleeves if your machinist will do it. This provides a nice sealing area for the HG.
Also unlike doing a factory stroker, these do not require clearancing at the girdle.
The wet paper towel idea to block ports and to shape water pump inlet works very well and easily removed.
When having the crank ground I wanted a racing clearance for the rod bearings. Iirc, I specd .002. I believe that info is in my original thread.
Thanks Sid. Great input. I will incorporate a lot of this in the write-up.
Old 01-29-2014, 05:18 PM
  #33
refresh951
refresh951's Avatar
My floor was 1.6-1.7 inches below the deck. I did not use flanged sleeves but I believe Duke did IIRC.
Old 01-29-2014, 05:44 PM
  #34
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
Really stupendous job here Shawn! Very valuable, well organized information. I need to build one of these just for the experience.
Old 01-29-2014, 06:07 PM
  #35
86 951 Driver
86 951 Driver's Avatar
My question is how well does the engine cool. I would be concerned filling it up that much water can't get around the whole cylinder.
Old 01-29-2014, 06:13 PM
  #36
refresh951
refresh951's Avatar
The motor cools fine, no heat issues what-so-ever. I think Porsche realized this as they raised the floor quite a bit on the 3L blocks. Drove my car all summer here in Hotlanta with no problems.
Old 01-29-2014, 10:55 PM
  #37
Dave W.
Dave W.'s Avatar
That's good to hear. I just measured the floor depth on my filled block and coincidentally it's right at 1.65".
Old 01-30-2014, 01:36 AM
  #38
blown 944
blown 944's Avatar
Most of the cooling is done around the head surface. It is a good idea to use a larger oil cooler to mitigate a possible rise in oil temps.
Old 02-09-2014, 09:27 AM
  #39
p5th
p5th's Avatar
Any new info? What bearings used? Any new tips? Best turbo to use? Favorite candy bar? Anything.
Old 02-09-2014, 11:32 AM
  #40
refresh951
refresh951's Avatar
Yes, more info coming soon. Give me a day or two.
Old 02-09-2014, 03:33 PM
  #41
URG8RB8
URG8RB8's Avatar
Looking forward to that! Can you add a section on what benefits if any to starting with a 3.0L block? I like the idea of the Siamese cylinders and oil squirters even if not necessary. Along with what you would consider "too big" . I think 3.3L is about the biggest, but Sid and yourself are the experts.
Old 02-09-2014, 04:36 PM
  #42
blown 944
blown 944's Avatar
The immediate benefits of using a 3.0 to start are the factory oil squirters, larger bore size to start,siamesed cylinders, the factory raised floor (although with a deck plate that's minimized).
I could make mine a 3.3 using the 2.5 block to start, since I'm using ductile iron thinner sleeves and deck plate. I just need a 3.0 crank and different pistons. Going the same route on a 3.0 block, you could do an even larger bore. Tbh though, unless you are going to a 16v head, the resulting added bore wouldn't yield much more power.
A 3.3 is the easiest larger engine as the bore size is the same as a 400 sbc and pistons are readily available. Sleeves are also easily attained. Along with not needing a deck plate or dartons.
The largest combo I've come up with, short of adding a welded stroker crank, is 3.6L. I dont see a reason for it though.
Old 02-09-2014, 04:51 PM
  #43
URG8RB8
URG8RB8's Avatar
Thanks Sid! I guess the squirters work better than the squirrels! Ha Ha Ha, just saw the typo and corrected it. Does filling the block effect the windage ports on the 3.0L block?
Old 02-09-2014, 05:38 PM
  #44
blown 944
blown 944's Avatar
No, and that is also a benefit ( the windage ports) Along with a larger water pump.
You wouldnt fill a 3.0 anyway.
Old 02-10-2014, 10:09 PM
  #45
refresh951
refresh951's Avatar
Added some more info.
Quick Reply: Blown 944 Hybrid Stroker DIY Guide
