Moton Club Sports/RE camber plates
FS
Moton Club Sports, Rebuilt less than 1K ago, Racers Edge camber plates, excellent condition. These were on a street car so no track time since rebuild.
$3350.00 plus freight. 205-703-5467 egan968@belllsouth.net
14" StopTech floating rotors, MO30 951 Calipers w/adapter brackets, 968 hubs, stainless lines. Bolt on kit for 951,S2 and 968 $1500.00 plus freight.
205-703-5467
High Strung chrome moly control arms, 19MM extended ball joint pins, 968 spindles machined for 19MM pins. $750.00 plus freight. 205-703-5467
93' 968 marble gray door panels complete front and rear with speakers and hardware. $400.00 plus freight 205-703-5467
205-703-5467
How is the top edge of the door panels by the window? Mine are starting to delaminate there. If in really good shape I'm interested! Also interested in the suspension but not sure I can quite swing that much $$ for a street car. Will give it some thought.
Pictures would be great. If they are substantially better than mine I'd be quite interested. Mine have what seems to be water damage or something on the top edge, it's expanded such that the rubber lip against the window doesn't stay in place properly and the black vinyl is peeling back. The rest of the card looks virtually new. Where are you located?
