Making changes to Turbo
Old 05-14-2014, 10:57 PM
refresh951
refresh951's Avatar
Originally Posted by Pauerman
PM me your name and I'll look up your invoice. Based on backpressure tests of the #8 vs the #10 - nothing else changed, the #10 was a clear winner on reducing backpressure without any loss in spool performance.
The issue here is availability. Turbonetics will no longer make a #10 KKK replica unless you're willing to commit to a batch order of 50 units. Clearly there is a perception that a #10 is too big for a 2.5L engine, but the reality is that if you put a standard Garrett .63 housing - which is bigger than any KKK housing that will fit this 50 trim, it would perform even better.
Using a Stg 3 turbine wheel, a #10 turbine housing works very well with a 50, 60 trim etc.
Thanks Vic! Great info.
Old 05-14-2014, 11:54 PM
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
Thanks Vic!
Old 05-15-2014, 12:28 AM
onspeed
onspeed's Avatar
PM sent.
As I mentioned to Vic in my PM that I don't think Rob got it from him. I recall him telling me (or reading one of his posts) that he had swapped out the hotside himself to a #8 from a #6.
edit - https://rennlist.com/forums/944-turb...m-on-2-5l.html refer to post 9
Old 05-15-2014, 09:48 AM
refresh951
refresh951's Avatar
Originally Posted by onspeed
PM sent.
Thanks Chris! I sent an email to Rob asking about it also. Not sure if the email is still good but we shall see.
Old 05-15-2014, 10:52 AM
gruhsy
gruhsy's Avatar
My impression of things I have read on RL is that the #8 can end up causing high back pressure that was my think on changing out the housing.
Does Tial make a housing that would fit this turbo? So far we have Vic's suggetion
Old 05-17-2014, 11:35 PM
refresh951
refresh951's Avatar
Rob got back to me and he confirmed it was definitely a #8 hotside. He said he did not get it from Vic.
Quick Reply: Making changes to Turbo
