Refresh951 - The Ideal Street/DE Suspension
Couple weeks ago Josh B and myself helped Brad (ilikemy944) install some suspension mods. He had Koni Sports all around and he added stiffer springs (350 lb) up front and added 30 mm torsion bars in the rear (effective rate 335 lb, see here) and he lowered the car about 1 inch. The car was completely transformed at the track. Brad stated that his 951 handled better than his 2008 Cayman S! The car also did not feel obnoxious on the street. Very impressive results and very low cost.
Obviously, you can throw A LOT of money at this but what fun is that.
So, what would you consider to be a low cost, biggest bang for your buck, street/DE setup?
Bilstein B6.
Better than the basic Koni yellows for about the same price. Your car being an '86 your struts should feature the threaded collars already, so installation should be a breeze.
Looks like Paragon Products has them in stock.
http://www.paragon-products.com/Bils...30-0104-do.htm
http://www.paragon-products.com/Bils...p/b36-2052.htm
It's amazing how different setups work for different cars and drivers. I run 350f and about 250r and get no understeer at track speeds but can induce some oversteer if wanted. This is generally on third and fourth gear turns. However, on very tight corners, (like 1st gear auto cross turns) I can get understeer. This isn't unexpected as the weight transfer is completely different in these conditions.
I also run Hoosiers or slicks, so that may also are a difference. I have always used the 1.0f:0.7r wheel rate ratio guide for setting up the balance. Then tune the rear sway if needed to suit.
Cheers
Cheers
how painful is 500f/350r setup on the street for a car that is not DD but rather a sunday/ocasional track driver?
I have 425# front with 30mm tb, and with NT-01's at 255/40-17 in front and 275/40-17 rear it is very neutral. Ride is great on street with stock Koni sports. Mike
This isn't directed just at you, as I see people put this stuff out there all of the time. But you can't have any idea how that is without knowing anything else about the car. Sway bars come into play. Damper settings come into play. More importantly, tire sizes come into play. For example, when I was running 245's at all four corners, I ran 650's front, 550's rear, and the car was balanced (30mm front bar, 19mm rear bar). When I went to 245s/285s, I changed my rear springs to 850's. When I changed from Leda to MCS, I went either 700 or 750 front, and 1000 rear. I initially had a tad bit of oversteer, but I adjusted the dampers (I believe I softened up the rear compression one click from what the MCS factory recommendation was).
Honestly, the JoshB has it - an inexpensive, already built, NA track car. I know that isn't what the question was, but here's the rub.......when you are a Group 1 student, and I don't care HOW fast you are, you really aren't going to be able to find the limits of something that is still streetable. As you progress, you won't be able to drive very well on the track in something that is streetable.
