Nissan Quest Alternator
06-09-2014, 11:25 PM
What length 6rib belt fits with A/C compressor? Thanks, Mike
06-09-2014, 11:42 PM
I have the griffiths compressor and ended up using the OE size belt.
06-09-2014, 11:53 PM
Mike, I used a 27.3" belt. Ordered from Summit Racing.
06-10-2014, 10:15 AM
06-10-2014, 11:52 AM
06-10-2014, 06:56 PM
Gates K060380 OR 6PK969
13/16 X 38-5/8
20mm x 981mm
06-22-2014, 10:17 AM
I ended up using a Dayco 5060380/6PK0965 38" belt. Thanks, Mike
06-22-2014, 02:43 PM
06-22-2014, 07:28 PM
If you get the correct 6 rib pulley you can use the stock belt. If you use the old pulley from the stock alt. You need a smaller belt
