Brittle Wiring Harness - rewrap with?
Old 07-07-2014, 11:45 PM
Brantley
Brantley's Avatar
Default Brittle Wiring Harness - rewrap with?
In the middle of replacing my down pipe due to an exhaust leak so have the intake and turbo currently off. I'm glad that I am going through the process as I have found a couple of problems.
One of my main concerns is the brittle parts of the wiring harness that run under the intake as I found the knock sensor wiring completely severed (yes, car was running like crap and this must be the reason why). Much of the wires are now exposed. I'd like to rewrap these wires throughout this area of the harness.
What does everyone recommend using to rewrap these areas? Electrical tape? Or, something more substantial? I saw the local auto parts store sells high temp tape like stuff.
Appreciate the feedback and / or recommendations.
Old 07-08-2014, 12:31 AM
dizzyj
dizzyj's Avatar
Best way is to get new wires from lr and run all the way to the dme.
Old 07-08-2014, 12:47 AM
bumflick
bumflick's Avatar
+1 on Lindsey. I am replacing the knock sensor and temp sensor and wires under the intake manifold.
Old 07-08-2014, 01:24 AM
gpr8er
gpr8er's Avatar
rebuilt my entire harness with this product about 5 years ago. Same stuff as used by Lindsey. Good to 210c
http://www.ebay.com/itm/65FT-HILEC-7...-/321189539656
Old 07-08-2014, 01:42 AM
Tom M'Guinn
Tom M'Guinn's Avatar
Right -- a good heat sleeve is your best bet (along with new wires as needed). Summit Racing sells plenty too...
Old 07-08-2014, 08:25 PM
Ronin-951
Ronin-951's Avatar
Just as a baseline, I believe that Ossi said 'Blue J' Hockey Stick Tape was a match for the stock wrap.
Old 07-08-2014, 09:09 PM
ncbrock
ncbrock's Avatar
I've used black hockey stick tape for numerous car wiring projects, it looks nice and doesn't become brittle. Although it is probably not heat resistant like the fiberglass sleeve type stuff.
Old 07-09-2014, 08:31 AM
MikeV
MikeV's Avatar
I've been using this http://www.wirecare.com/products.asp?prodline=nm
Looks like the sleeving Lindsey uses but more flexible.
Old 07-09-2014, 10:50 AM
67King
67King's Avatar
+1. What I used, as well. I believe that the hard plastic used originally hurts the harnesses, because the wires have only a small amount of room they can flex. With the nylon mesh, much more of hte wire can flex, putting less stress on the wire where it goes into the connector. I rebuilt my entire wire harness myself for much, much less than any one of the various kits that are out there.
Old 07-09-2014, 01:56 PM
arthropraxis
arthropraxis's Avatar
Is that hose expandable to slip over the connector end of the wires?
Old 07-09-2014, 06:10 PM
Brantley
Brantley's Avatar
Thanks all... very helpful. I'll get some of the fiberglass sleeve stuff that Lindsey uses. I did buy the LR knock sensor replacement as my wire is shot...
Quick Reply: Brittle Wiring Harness - rewrap with?
