Are there Stock AFM Performance Modifications
This is probably a dumb question, but you can just call me "Dummy" if you have a good answer!
I am trying to keep my 1986 951 as stock looking as possible and parts I put on ones that where available options (more or less) due to the low mileage of my car. I am just getting into the performance tweaking so excuse any stupidity on my part.
My question is: Can you modify the stock AFM to accommodate more than 320 HP? Are there shops that port and polish for example, or make mods so that the car looks original but breaths better?
I know there are many parts to the equation, I plan on getting a K26/8 and having it rebuilt with modern parts, I am told that could top out at around 350 RWHP, if all things are right. I have been stock piling performance parts: 3 bar adjustable pressure reg, 55# Fuel Injectors, LR dual port wastegate, manual boost controller, boost and a/f meters.... I plan on looking into modified intercooler and A-Tune, but perhaps that is all overkill for this application.
In the end I just want to have my car appear stock but get the most performance out as I can while respecting the low mileage vehicle, with all that said from reading the forums it sounds like the stock AFM will probably be the limiting factor and I don't want some big MAF setup under the hood and as far as I know Vittesse is the only one making a stealth one and that seems like more modifications than I want to do on this car. I just thought maybe there were performance modifications that could be made to the stock AFM and wanted to know what they are and who does them? Thanks for your time.
It's kind of funny that I saw your post since only glance here every few months these days. Here you go-
https://rennlist.com/forums/944-turb...-pictures.html
You can just buy my car and get it over with..
Kevin
Kevin
Thanks for the link, you have done some very nice modifications and upkeep on your car, I would love to buy your car, but doubt I could afford it!
So you bought a stealth from Vittesse Racing and modified it to your air box, I know he sells the stealth, but not a lot of good pictures on his site and hard to find it and pricing on his site on the stealth MAF.
I was hoping there were mods/enhancements that could be made to the stock one, but probably not. Thanks again for commenting and sharing the link to your amazing work, I lucked out timing wise it seams! Hey, what does the outside of your car look like, I know your engine compartment is spotless!
Freedom Enthusiast
There are vendors that sell chip upgrades for the stock AFM. With some of them you do need to upgrade to a 3 bar fuel pressure regulator but everything will look stock. You can add a manual/adjustable boost controller but you would not have to.
I have a Vitesse AFM chip that I am trying to sell. $200 shipped.
You can port out the AFM and it will flow a bit more, just be sure not to mess with the area where the flapper seats. I have a ported 86' AFM but I think the resistor strip is done, I have no idea how much more than a stock AFM it flowed, I switched to stand alone shortly after porting it so I don't really know if it was worth my time truthfully.
Professional Hoon
I see it as more of a inconvenience IMO. If you try get your AFM to flow more air, that means the voltage vs CFM will change. That means you'll need a different tune, nothing off the shelf will help as they only with with the standard AFM.
AFM Info
Here is some information on the air-flow meter. This is from Bosch Gasoline Fuel-Injection Systems L-Jetronic and Bosch Fuel Injection & Engine Management
Thanks for that bit of information, exactly why I am asking, always good to hear the Cons as well as the Pros/Means and Methods. I appreciate everyone sharing their knowledge.
I am planning on getting an A-Tune, just trying to figure out all the mods so when I get it, it is optimized for my build and that it is the final build for this car, trying to be smart about it, but also have no regrets for what I should have done.
Professional Hoon
- 3 bar FPR
- Dual port wastegate. Tial 38mm and fejjj has adaptors ( https://rennlist.com/forums/944-turb...-adapters.html )
remove the cat or high flow cat if you wish, always frees up power.
Easy.
- 3 bar FPR
- 3 bar FPR
Just patiently acquiring the parts so I can put it together at once, after this work I will focus on the suspension and braking, or could be I do that first if I see a good deal. I realize suspension and braking are probably more important that the engine performance, but that is a whole other topic all together.....
