Where to buy exhaust manifold flange?
Old 09-16-2014, 02:04 PM
Forty-six and 2
Forty-six and 2's Avatar
Default Where to buy exhaust manifold flange?
I am looking to build my own manifold, but can't find the head flange anywhere. Does anyone have a source?
Mild steel would be preferred, but SS isn't a problem either. Joined or separate doesn't matter.
Old 09-16-2014, 02:24 PM
marcoturbo
marcoturbo's Avatar
Like this one ?
http://www.9products.com/exhaust-flange
Old 09-16-2014, 02:35 PM
Forty-six and 2
I did see that one, but was hoping for a US supplier. The value of the US dollar makes that a very expensive flange!
Old 09-16-2014, 03:35 PM
azmi951
azmi951's Avatar
Do you have a CAD drawing of the flange? A friend of mine can make them on his laser cutter. SS or mild up to 1 inch thick or down to 10 gauge plus or minus .004 on 1/4 steel.
Old 09-16-2014, 05:37 PM
pole position
pole position's Avatar
Quality is never cheap and cheap is rarely quality...if the 9 product is not in your budget then make your own using a plasma cutter, drill and hole saw , easy on mild steel .
Old 09-16-2014, 06:33 PM
Forty-six and 2
I don't have a cad drawing, but I can give you a precise drawing with the center to center measurements. Let me know if he could work with that, and what the cost wood be 5/8" mild steel. I would need 4 single port flanges, rather than a joined flange. Let me know if he is willing, and thanks.
I'm not expecting cheap. I am expecting a quality machine cut flange. Even a quality flange is not work an upper $100 price tag. I have purchased many quality flanges in the $75-120 range.
Old 09-16-2014, 06:48 PM
fortysixandtwo
fortysixandtwo's Avatar
You could pick up a set of cracked headers, and cut the flanges off of them.
Old 09-16-2014, 06:52 PM
azmi951
azmi951's Avatar
I can do center to center hole size and punch it out on SolidWorks. He does not cut 5/8 very often. 3/8 is a common size he cuts and that is still very thick. Are you sure 5/8 is what you need?
I'm guessing but it would probably be about $5-10/ flange for the individual flanges.
email a rough dimensioned sketch at martinez.sean.s@gmail.com
Old 09-16-2014, 07:05 PM
Forty-six and 2
It needs to be fairly thick in order to flatten it after welding. 3\8" just isn't enough material to do that. 1/2" would be fine if it's something that is more available for him.
I will draw it and email it when I get off of work. Thanks again.
Nice screen name! I would prefer to start with a solid flat flange, rather than the stamped stock one.
Old 09-16-2014, 08:18 PM
azmi951
azmi951's Avatar
Sounds good. My buddy just upgraded his laser to a Trumph L2530. Nice machine.
I will draw it up and send some prints back to you.
I can also run a test sheet in 1/8 for fit checks. 1/8 is really cheap to cut.
Old 09-16-2014, 10:18 PM
Tsmith84
Tsmith84's Avatar
I'm interested in one as well. Thanks.
Old 09-16-2014, 10:30 PM
gpr8er
gpr8er's Avatar
http://www.reidwashbon.com/racing_pa...t_flanges.aspx
Old 09-16-2014, 10:38 PM
admiralkhole
admiralkhole's Avatar
Two users with a forty six and two name? Lol
I LOVE that song.
Old 09-17-2014, 12:14 AM
Forty-six and 2
Email sent.
Sounds like a plan. I'm not in a big rush. Keep me updated. Let me know the cost of the process. If he needs me to, I will buy a 1/2"or 5/8" plate and have it shipped to you.
Old 09-17-2014, 03:55 AM
Dutch944
Dutch944's Avatar
I cut my 16v flanges out in SS316 1/2" (12mm) But as we used a 1" thick base plate on to bold them on during welding, we never needed to flatten the flanges!
Quick Reply: Where to buy exhaust manifold flange?
