944 Turbo motor value
I've been getting parts together for my 5.3 swap. I'm planning on selling the motor & harness etc. How much should I expect or try to sell it for? It has a few minor leaks on some rear seals, the DME needs to be fixed (I found rebuilt units for $350 online w/core exch), prob good idea to do water pump etc while it's out, etc... I want to be fair but don't want to short change myself either.
Sorry for the slow response. 159k, it does run but the computers need to be fixed. The compression and leak down tests should be done today. I'm in Birmingham, AL.
1 Post
For someone looking to turbo an n/a, if you're including all turbo parts( turbo, intercooler, intake peices, exhaust, etc.) 1k at the most. 156k miles isn't a huge amount on these motors if well maintained, but its not exceptionally low either.
My. 02 cents
My. 02 cents
It's still in the car. I did get some good pics and have the comp/leak down #'s
Compression
#1 155lbs
#2 170lbs
#3 150lbs
#4 170lbs
Leak down
#1 4%
#2 4%
#3 3%
#4 2%
Compression
#1 155lbs
#2 170lbs
#3 150lbs
#4 170lbs
Leak down
#1 4%
#2 4%
#3 3%
#4 2%
What is your time frame to remove the engine. I have an open time line for a replacement engine. I am going from n/a to turbo, so I will need all the pieces, except the intercooler.
I am in Atlanta and can pickup the engine.
770-368-9550
Alan
770-368-9550
Alan
