89 turbo caliber
Old 12-01-2014, 09:41 PM
ksui951
ksui951's Avatar
Default 89 turbo caliber
anyone know where i could find the seal and dust cover for the front caliber
i plan on useing the same piston...
Thanks in advance
Old 12-01-2014, 09:53 PM
Dougs951S
Dougs951S's Avatar
Costs more to rebuild the 4 piston brembos than its worth in my opinion. You'll need 2 each (per caliper) 36mm and 40mm seal kits for the front and 2 each per rear caliper 30mm and 28mm kits for a total of 16 "seal kits" for each of the 16 pistons on the car's brakes. Be sitting down when you figure out how much its going to cost you, they're expensive since each kit comes with a new (usually unneeded) piston. They are all available from 944online.com. Don't be surprised if the parts are in the neighborhood of 700 bucks.
Old 12-01-2014, 10:03 PM
ksui951
ksui951's Avatar
Hello Doug.. how many hp are you pushing with that baby..
Old 12-01-2014, 10:22 PM
Dougs951S
Dougs951S's Avatar
I don't know, it's never been dynoed so all I have to go off are datalogs of air mass flow and some derivations based on AFR, engine speed, and fuel mass data. I'd estimate 375 rwhp. It's pretty quick for a stock internals 2.5 liter car with a smallish turbo, but the bottom end is about all that is stock on my car...
Old 12-02-2014, 12:39 AM
divil
divil's Avatar
I bought all the parts for about $400 from Paragon. Well worth it in my opinion. That price was for the seals and dust boots, without pistons - all my pistons turned out to be in perfect condition, which I would bet is fairly typical.
Be aware that there are 2 types of caliper used on the '89 Turbo. The early type, used on '88 Turbo S and early '89s used a scraper ring instead of dust boot. These scraper rings seem to be hard to get but most people say they are usually fine to re-use. The later '89 calipers use a rubber dust boot which you really need to replace, but they are readily available from Paragon and other sources (my price above included these).
http://www.paragon-products.com/Brem...-kits-late.htm
If your pistons are ok you will have a like new set of calipers for just over $400 and a few hours work...bargain!
Old 12-02-2014, 12:48 AM
fejjj
fejjj's Avatar
I have a complete genuine Porsche rebuild kit for your 89 M030 calipers.
Please send me a PM if interested.
I was going to use these to rebuild mine but bought a rebuilt caliper set.
Old 12-02-2014, 01:19 PM
mj951
mj951's Avatar
I bought parts from http://www.zeckhausen.com/ when I rebuilt mine.
Also saw a thread on the Racing / DE forum from LC Motorsports that they supply Brembo brake parts and of course as previously mentioned you can't go wrong with Paragon Products.
Good luck.
Old 12-04-2014, 10:19 AM
Willard Bridgham 3
Willard Bridgham 3's Avatar
You mean caliper?
Old 12-04-2014, 01:33 PM
odb812
odb812's Avatar
Originally Posted by Willard Bridgham 3
You mean caliper?
That or he thinks this is a Dodge forum.
Old 12-06-2014, 11:34 AM
ksui951
ksui951's Avatar
yes yes fejjj
Quick Reply: 89 turbo caliber
