Steel Wide body LS3
Old 01-11-2015, 04:07 PM
Max Energy
Max Energy's Avatar
Default Steel Wide body 951/LS3
Finally got back on my 1989 Turbo LS3 Hot Cam conversion. We actually widened the steel body both front and rear to accommodate 12X18/335x30 rears and 10X18/275x35 fronts. Added new fiberglass hood with heat extraction vents and right and left side exhaust. We are completing the custom rear diffusor. I will start posting the progress.
Max
Old 01-11-2015, 04:13 PM
Max Energy
Max Energy's Avatar
Default Early in Process
Early pictures
David Floyd
David Floyd's Avatar
Very nice work
Old 01-11-2015, 04:21 PM
Max Energy
Max Energy's Avatar
I will forward some pictures of the engine bay later this week. Smoothed out the firewall and removed and filled all the holes except for the main harness and fuel line. Also removed all the dimples and brackets on the inner wheel wells. Will be mounting 968 mirrors and door handles along with the front turbo bumper with a Tony G front splitter color matched
Max
Old 01-11-2015, 05:10 PM
arthropraxis
arthropraxis's Avatar
Nice. I like that hood.
Old 01-11-2015, 06:13 PM
Jherriott
Jherriott's Avatar
When you grind right down to the metal like that, the hot dip zinc coating is gone. How do you ensure that rust never gets a foothold? Especially on the inside, hard to reach areas where moisture might live.
Old 01-11-2015, 07:04 PM
rlm328
rlm328's Avatar
Here is an idea for your rear fender. Pre and Post paint
Old 01-11-2015, 09:37 PM
Cyril
Cyril's Avatar
Very Nice!
Old 01-11-2015, 09:38 PM
pormgb
pormgb's Avatar
Wow, very nice!!
Are you going to run dual side pipes?
Old 01-11-2015, 09:55 PM
Max Energy
Max Energy's Avatar
Gentlemen,
We metal etched all the bare metal then primed, sealed and painted. With the interior out of the car you have full access to the inner fenders. Yes I am going to run dual side pipes. We are using a LS3 Hot Cam motor making near 500 HP we are using 1 7/8" Kook's custom long tube headers going into a Burns 4" Oval merge collector, then we have 4" oval SS tubing going to another Burns merge collector from 4" to dual 3 1/2" oval to each side then to dual SS round outlets similar to the original 918 design. The picture that Bob references with the rear fender vents is similar to what we are doing to the front and rear one of our 944 Track race cars with a 350+ HP 968 NA race engine.
Max
Old 01-11-2015, 11:59 PM
C ANDERSON
C ANDERSON's Avatar
Max,
Looks great can't wait to see it.
Clifton
Old 01-12-2015, 12:42 AM
Weston Dillard
Weston Dillard's Avatar
Very cool Max! Used a similar technique on my fenders, but since I was learning as I went, it's not nearly as well done.
West
Old 01-12-2015, 12:29 PM
Spidey944
Spidey944's Avatar
Beautiful! I am anxious to see more pics! The rear panels look amazing.
Old 01-12-2015, 03:36 PM
Techno Duck
Techno Duck's Avatar
Looks awesome! Great craftsmanship. Looking forward to seeing that side exhaust finished!
Any more details on the hood? I really like the look. Does it negate the need for crossmember spacers?
Old 01-12-2015, 06:28 PM
ian
ian's Avatar
Awesome stuff, the 951 has great hips to begin with, but this takes it up a notch. Keep us updated!
Quick Reply: Steel Wide body LS3
