Tial SS HTA G35 .82 turbo review
I was out of the country during the holidays, and finished the TIAL/Garrett turbo installation last Saturday. Upon startup, the turbo was actually building enough boost to force the BOV to slightly open for vacuum. We had to retune the Electromotive for idle, part throttle, etc. The maps designed for the Precision caused bucking, stalling, etc. We cleaned it up and went WOT to see the low boost (Greddy 1 bar 14.7 psi) setting using the Presision Turbo, the TIAL turbo hit 20psi immediately. We turned down the Greddy with no control. We then went to the high boost level to see if we had control, and let up at 23psi by 3300rpm, turned the high level down and hit 20 psi again. I'm installing a 7psi spring tonight to get the low boost setting back in control using a much lower PSI internal spring.
We still have some tuning to do, as we went rich everywhere just to be safe until we have the time on the road and mustang dyno to get the new turbo dialed in. We were surprised the tuning had to be so drastically changed just from a turbo replacement.
This unit is so driver friendly the car doesn't feel like a turbo motor. You have immediate boost, and hit 20psi well before 3500rpm. I'd have to read the data logs to say exactly when, but things are happening fast when driving. In 6th gear on the freeway at 1800rpm, I have 4lbs of boost by 2K. This is the fastest spooling turbo I've ever had on these cars and it outflows the shelf Garrett GT35 .82. We'll work on the timing, fuel, etc. to find how well this unit really works on my car.
The ceramic coating on the intake, and heat emitter coating on all boost tubes and intercooler work. The intake air temps are less then ambient. We'll know the numbers when we get to the dyno. Impressive stuff and worth consideration.
TIAL recently sent a killer hotside blanket in black that I'll install this weekend. They've tried all brands, and this worked by far the best including all ceramic coatings. You can't see it anyway, and I just want things as cool as possible. My water temps are 20 degrees lower, and oil temps are cooler when stopped at a light.
Here are a few pictures of the install and coatings.
G
G
Congrads on the new setup. Thanks for the update. Just curious. Can you measure pre turbo boost pressure on your crossover pipe?
I'm thinking this turbo is what I will use on the new project car. I don't know yet if the compressor I have is a GT30 or GT35.
Professional Hoon
For example my cousin bought a gt3576r for his 2jz rx8 drift build. You can measure the wheels and and you'll know what you have.
on a 2.5L a gt3582r is just to big.
Just got home and did a 4th gear pull from 2200rpm. Hard to tell, but this turbo is hitting 20psi by around 3200rpm. Crappy video, and we've much tuning work to complete. Amazing what TIAL has done with the GT35/.82 turbo with their housings and wheels. I've driven a few GT35 cars, and this unit is impressive. First one on a 951...
G
That's a great turbo. Both cw and myself were very impressed with the minimal lag and overall performance, no weak points.
Our cars look very similar and what's funny is my intake...was all black and I changed everything to polished now I see you have changed to black lol.
What cam are you using?
Neat meeting you in Melbourne. Chris was impressed with your printing glass work, your "first" car and you. Give him a call, he's interested in your glass work in their dealerships. He commented, "I like that mate." He's going places.
G
G
Professional Hoon
Paul,
Engine is going to be the 2.85 offset grind. In process of pulling blown engine from the RAGE2 car. Yes sorry I guess I mean turbo
Professional Hoon
You probably should get a GT3076R or GTX or HTA. They're a plenty size turbo. .82 turbine housing. Or even a 3576R.
A 3582R is on the money for a 3L
Unless you don't mind lag!!
