60-1 Hifi thoughts on a 951
Old 02-22-2015, 09:23 PM
fiily
fiily's Avatar
Default 60-1 Hifi thoughts on a 951
So, I have a lead on a Turbonetics 60-1 for my 951. I have read some older threads and people thoughts are the 60-1 HiFi was laggy, ie boosts starts around 35-3800rpm's and generally the turbo is too big for the 8v 2.5L engine.
Can I get anyone's thoughts that ran this or not, and why you would or wouldn't stick this turbo in your 951?
I have the vitesse MAF kit, sfr 2.5" intercooler pipes, with a dansk cat-back exhaust, WB02 sensor, but the downpipe and wastegate are still stock, so those would be the next buys before a full exhaust.
My plan is 16-18psi, keeping it conservative and looking to pump out 315-335hp on 93 pump gas.
Car is getting repainted in the next 2 weeks, 18 turbo twists bought and in the garage, now it's sorting out the go-fast goodies.
Old 02-23-2015, 11:25 AM
MM951
MM951's Avatar
I've had that turbo for years - I love it. Without exhaust/intake leaks and a good tune, you will see 18psi by 3300rpm, positive pressure at anything above 2K, it hits hard, and sounds awesome. I've never wanted more. - it's a great fit for the 951 if you aren't fixated on the newest technology
Old 02-23-2015, 12:29 PM
ramius665
ramius665's Avatar
I'll be running a 60-1 on my 3L 16V and expect to see even better results than the guys mounting them on 2.5L 8V cars. It's definitely a better option than the K26/8 that so many people go with.
Old 02-23-2015, 01:44 PM
fiily
fiily's Avatar
I'm not, old tech is fine with me and my wallet. The one thing I did read was on the water pipe needs bending to fit around the hotside housing?
Either way, it's will be a definite upgrade from my 26/6, as long as the price is right.
Old 02-23-2015, 02:27 PM
pole position
pole position's Avatar
Lots of lag.....lots of backpressure
TO4E 50 trim if you like old school/ inexpensive ....done
Old 02-23-2015, 02:47 PM
fiily
fiily's Avatar
From what I have read, these do have plenty of backpressure, but my budget is always a concern, along with a blown headgasket.
Old 02-23-2015, 02:55 PM
pole position
Head gasket within reasonable boost levels is a tuning not turbo issue .
Stay stock if you look for the least amount of problems, can't beat Porsches R&D even when it happened 30 + years ago.
Old 02-23-2015, 02:56 PM
Ronin-951
Ronin-951's Avatar
Will this be on the 968 Aaron?, or are you swapping the 951?
Old 02-23-2015, 03:00 PM
v8killer
v8killer's Avatar
I run the 60-1 hifi. At 18lbs. it makes about 330rwhp and at 22lbs. it makes 368 rwhp on E85 Rogue Tuning M-Tune. On the street it really pull hard but on the track I find it a little laggy under 3600 rpm.
Old 02-23-2015, 03:47 PM
fiily
fiily's Avatar
This will be a street car, so running 18# boost 315-335hp sounds very reasonable with the 60-1 then.
Can you explain the water pipe mod? Is it just bending the pipe a tad more to fit clearances?
What other mods do you have to make the 330rwhp on your 944t other than Rogue's MAF? Trying to compare apples to apples.
Old 02-23-2015, 07:16 PM
v8killer
v8killer's Avatar
No water pipe mod. My turbo is only oil cooled.
Engine is a 2.5 with Wossner pistons,Wossner rods, cross drilled crank, 3" exhaust,spec billet lightweight flywheel,stock O-ringed head, and SFR FMIC.
Old 02-23-2015, 08:28 PM
Techno Duck
Techno Duck's Avatar
Ran a 60-1 HiFi in my car as well. 18psi @ ~3300rpm is a good estimate. I had a triple-K #8 hotside replica also. Its a bit of a lazy turbo and after looking at the compressor map many years ago i figured it would do much better at higher boost levels... which i didnt care to push. Always kept mine at 15psi.
My car made just under 300whp at 16psi with the usual bolt ons; 3" exhaust with no cat, Tial 38mm, Vitesse MAF, SFR FMIC. A bunch of other stuff done also but nothing that would add power. Infact if i remember right i sold v8killer something off my engine when i parted it..might of been the turbo or FMIC!
Its sort of inbetween the LR Super 61 and Super 53. My friend has a ball bearing Super61 and even untuned it spooled up way faster than my car ever did.
Like you said, its an old school turbo. I would only go for it if the price is right.
Old 02-23-2015, 11:39 PM
fiily
fiily's Avatar
What's the right price? $400-$450 is my thought. Otherwise I will spend a little more a get something newer, just not looking to spend $900 right now on a turbo. Spending $$$ on a entire repaint, rims and tires just purchased, still would like to purchase the WG and Downpipe, gonna be buried in the car, but it will look great!
Old 02-25-2015, 03:36 PM
fiily
fiily's Avatar
60-1 hifi on its way to its new home! Time to start wrenching again.
Old 02-25-2015, 06:26 PM
ramius665
ramius665's Avatar
Picked up a S2 engine a while back, in the process of rebuilding it as a 16V turbo engine. 968 is still totally stock and the 2.5L engine out of the 951 will probably go up for sale when I drop in the new motor.
Quick Reply: 60-1 Hifi thoughts on a 951
