Gruhsy's revival of RAGE2's old car
Old 03-26-2015, 03:08 PM
gruhsy
gruhsy's Avatar
Just the lighting on the rods. I won't ever use them however.
SDS system is gone.
Originally Posted by cruise98
Rage... a blast from the past. There is probably some video of him doing burnouts and donuts with that car. Did the car still have the Simple Digital management system on it? Some of the rods look bent.
Old 03-27-2015, 01:55 AM
blown 944
blown 944's Avatar
Originally Posted by gruhsy
Thanks Sid I will take your advice on that. I am guessing you mean because they won't work for an offset grind. Would they still be good for a normal build or do you recommend scraping them all together? The 3 pistons appear to be completely undamaged along with the rods....would not use rods however.
The block and crank girdle are toast. You can see right from one side to the other on piston 4. Amazing to me is that the rod bearing even on the broken rod is completely undamaged. I assumed a bearing seized until I took apart the engine.
I have the original 40000km block from my other car, it will be a sleeved 2.5L.
I'm thinking of using the same pistons Shawn used.
Actually since you asked I have a question for you. Will 4.040 or 4.060 pistons work with the sleeves you and Shawn chose, cylinder wall thickness related? I searched but have not found an answer.
I have 3 2.5L cranks and 3 cylinder heads and 2 cam towers to choose from. Probably going to use the Michael Mount head for the first engine.
At some point I will pick up a second block but that's last on the list and will most likely be a 16V head from MM.
Yes, for an offset grind they are useless. I suppose you could measure the skirts to be sure they aren't collapsed. I'm not sure what you'd do with them though..
You should be able to bore it to 4.04, but I would start at 4.030 to be able to do one cleanup if needed. If your're sstarting with a 2.5 crank, you'll either want to use the Pistons I used in the original build, or the ones Shawn did in the second build.
Old 03-27-2015, 01:50 PM
gruhsy
gruhsy's Avatar
K awesome thanks for the advice on that.
stumbled across this place. expensive but looks like one kit uses off the shelf chevy pistons. I would hope the cost included installing the sleeves.
http://lnengineering.com/products/wa...-944t-968.html
Old 03-27-2015, 04:02 PM
blown 944
blown 944's Avatar
None of that will work with a stroker. I think some are plated.
Best thing to do is plan it out with a local machine shop that is comfortable with installing iron sleeves in an aluminum block. Spec ductile iron flanges sleeves and you should be fine. Make sure they leave them proud about .002 for settling.
Old 03-27-2015, 04:22 PM
962 kid
962 kid's Avatar
The original 106mm sleeves were done by Precise in Calgary, I beleive they are a Rolls Royce part. They also have a great crank grinding setup, and could easily do the offset grind.
Old 03-27-2015, 11:17 PM
David Floyd
David Floyd's Avatar
Rolls Royce chromolly sleeves is what I was always told by John A
Old 08-16-2015, 10:58 AM
gruhsy
gruhsy's Avatar
Not much progress except cleaning. I've been working on my neighbor's 86
Just pulled the head yesterday on his and found the metal ring on cylinder 1 was no longer round. Glad I pulled the head His car has taken up most of my time.
Will try post some pics of it today
Old 08-16-2015, 05:08 PM
V2Rocket
Rainman
V2Rocket's Avatar
You sure you don't want to offset a968 crank instead? I know a guy with one.....
Old 08-16-2015, 08:34 PM
gruhsy
gruhsy's Avatar
With the dive the Canadian dollar has taken lately things are going to slow down a bit.
I bought most of my stuff on par but now paying extra 30%.
Old 08-16-2015, 08:45 PM
gruhsy
gruhsy's Avatar
="3"%pics of glass beaded and primed strut tower
="3"%Check out the head gasket removed from the 86 turbo I'm working on. Good thing I pulled the engine out
Will have more pics soon of the 86 and the 87 RAGE2 car
Old 08-17-2015, 12:31 AM
Dave W.
Dave W.'s Avatar
That's the classic cyl 4 headgasket failure. Mine did the same thing.
BTW cyl 4 is closest to the firewall.
Old 08-19-2015, 11:22 PM
gruhsy
gruhsy's Avatar
Thanks for catching that. Didn't look close enough when I pulled it off. Was busy doing everything on car
QUOTE=Dave W.;12515085]That's the classic cyl 4 headgasket failure. Mine did the same thing.
BTW cyl 4 is closest to the firewall.[/QUOTE]
Old 09-09-2015, 12:24 AM
gruhsy
gruhsy's Avatar
Default progress on friends engine
Edit: car and engine is now mine as neighbor quit the project late summer/ fall 2020
Working on 86 as well as RAGE2 car.
Friends block going off to Michael Mount along with crank for offset grind
Block and engine parts cleaned up quite nice. Bottom of oil pan had contamination from sand and gravel due to previous owner driving it with an oil pan gasket that was bulging out in one spot. Very poor maintenance.
Nice to have a Hotsy parts washer at work.
Old 07-23-2016, 12:08 PM
gruhsy
gruhsy's Avatar
Well some progress now. The block in the above picture is now on route to Michael Mount and the crank is on route to Mile High Crankshafts in Denver. Co
http://milehighcranks
Old 07-26-2016, 07:04 PM
blown 944
blown 944's Avatar
Glad you're making progress.
Are you going off the shelf piston, or custom?
Quick Reply: Gruhsy's revival of RAGE2's old car
