Gruhsy's revival of RAGE2's old car
Old 03-24-2015, 03:10 PM
gruhsy
gruhsy's Avatar
Default Gruhsy's revival of RAGE2's old car
Well the final dissasembly of RAGE2's broken engine is done.
Will be posting pics as I go. Hopefully I will have time for some photos of the engine tonight.
It turns out #4 connecting rod snapped in half. The rods were 944 connecting rods. Wrong rods to use considering the power that was posted.
The engine has 106mm pistons and the rods were not RARST rods either.
Will have pics of the snapped rod. It is also twisted.
The crank turned out to be fine and none of the rod bearings or crank bearings were damaged....I will still use new bearings
The block, oil pan, 1 pickup tube, 1 piston and 1 rod are the only damaged parts.
The engine was also balance shaft delete.
Old 03-24-2015, 03:44 PM
MM951
MM951's Avatar
Wow, RAGE2 was a long long time ago. Glad to see the car is still around!
Old 03-25-2015, 01:37 AM
gruhsy
gruhsy's Avatar
pics of pistons and rods
Old 03-25-2015, 01:48 AM
lart951
Basic Sponsor
lart951's Avatar
who did that built? those are na rods so sad
Old 03-25-2015, 02:17 AM
David Floyd
David Floyd's Avatar
There are build posts and destruction posts from back in the day
Old 03-25-2015, 04:25 AM
Ski
Ski's Avatar
I am familiar with a feeling like that AND the sound. Sounds like $hit too.
Then the rod bust the block, then the oil hits the crossover pipe, then ignites, and then your rear view and side mirrors fill with orange flames: Note to Self - After your A$$hole releases you from the drivers seat, get the hell out of the car!
Old 03-25-2015, 07:38 AM
blade7
blade7's Avatar
The good news is 3 pistons are good. They are JE.
If I can find a replacent 4th piston I may have a 106mm offset grind motor????
I don't know who RAGE2 is but is seems like you've got the crank and 3 pistons out of his scrap block, I'd bin those pistons and start again, and check if the crank is bent. You can call it RAGE2 MK11 if you like but it will be a bit like Henry Fords hammer
Old 03-25-2015, 08:58 AM
gruhsy
gruhsy's Avatar
Somewhere on here there are a few descriptions about the car on old posts.
Just to be clear I bought the car with the blown motor. I picked up the car from Soloracer.
I will be fixing it properly. It was a local shop that build the car. I will have more pics of destruction tonight.
The crank is straight
I am going to be building 2 motors.....basically because I can.....it will however be a slow process, especially with the low dollar right now.
Old 03-25-2015, 09:02 AM
gruhsy
gruhsy's Avatar
I pack a 20lb bottle in my car and a couple 5's
Old 03-25-2015, 09:40 AM
V2Rocket
Rainman
V2Rocket's Avatar
nothing some jb weld couldn't fix.
i bet that made a biblical noise when the rod went.
Old 03-25-2015, 10:46 AM
Voith
Voith's Avatar
These rods are not as weak as everybody thinks, this car probably pushed some serious power.
Old 03-25-2015, 11:21 AM
gruhsy
gruhsy's Avatar
Post on here with race fuel was 461hp
Over the 400hp recommended.......common post here
I would also guess that a 106mm piston is more stress than a 101mm
Old 03-25-2015, 06:58 PM
blown 944
blown 944's Avatar
Just scrap the Pistons. If you are doing an offset you'll need new anyway.
Is the block toast? Are you doing a sleeved block? 2.5 or 3.0?
Old 03-25-2015, 07:58 PM
gruhsy
gruhsy's Avatar
Thanks Sid I will take your advice on that. I am guessing you mean because they won't work for an offset grind. Would they still be good for a normal build or do you recommend scraping them all together? The 3 pistons appear to be completely undamaged along with the rods....would not use rods however.
The block and crank girdle are toast. You can see right from one side to the other on piston 4. Amazing to me is that the rod bearing even on the broken rod is completely undamaged. I assumed a bearing seized until I took apart the engine.
I have the original 40000km block from my other car, it will be a sleeved 2.5L.
I'm thinking of using the same pistons Shawn used.
Actually since you asked I have a question for you. Will 4.040 or 4.060 pistons work with the sleeves you and Shawn chose, cylinder wall thickness related? I searched but have not found an answer.
I have 3 2.5L cranks and 3 cylinder heads and 2 cam towers to choose from. Probably going to use the Michael Mount head for the first engine.
At some point I will pick up a second block but that's last on the list and will most likely be a 16V head from MM.
Old 03-26-2015, 02:06 PM
cruise98
cruise98's Avatar
Rage... a blast from the past. There is probably some video of him doing burnouts and donuts with that car. Did the car still have the Simple Digital management system on it? Some of the rods look bent.
Quick Reply: Gruhsy's revival of RAGE2's old car
