Wish I could keep these but my 944s are all early offset. This is set of the no longer available (I believe) legendary Charlie A-arms. Also I have a set of Turbo M030 hubs and spindles with the spindles modified to accept a 19mm pin. Asking $3500 as pictured with the Racer's Edge caster blocks.
Would you split it all up? I am interested in the charlie arms only.
The problem is the 19mm pins. The stock pin size is 17mm so machining is required for these to fit on stock spindles. Either that or a 17mm pin which is involved to come by.
