What material is used inside the heat shield of the stock 951/951S Exhaust manifold?
Hey guys. Before I go into battle on a set of these, is there asbestos or something, inside of the heat shielding? I don't like the idea of dealing with asbestos, but if there isn't any, cool! TIA
Even if there is, you can take some reasonable precautionary control measures.
Use a simple soapy water mixture in a mist application using a spray bottle to control the material if you are concerned. Asbestos is only an issue if it becomes airborne.
I have removed them quite a few times, i don't like the look of the stuff. If i was to hazard a guess i would say its asbestos(even if it isn't i treat it as asbestos). Its pure white in colour and very fibrous. i soak the thing in soapy water before i cut the shields off and wear a very good mask.
Elliot, since you are taking yours apart, maybe get one of these kits and let us all know Link is to ACE hardware since they're everywhere, but the kit is even cheaper (under $10) on the internet... We can even start a little collection to cover your cost. Would be great to know for sure...
http://www.acehardware.com/product/i...pla=pla_983150
lol. Theoretically, I'm trying NOT to take it apart, but I want to inspect it for cracks. I'm certain that it is cracked, and I want to eyeball it, but ugh. Nice kit though!
Check with Crazy Eddie. He made up a testing station with a kiddie pool where he'd dunk them under water and look for bubbles. Worked like a charm, just can't remember how he sealed the ends. But I know Eddie, so I'm confident he used something free that was laying around the house...
Hummm the older I get the more brain cells I lose
I think I use drain plugs that I had used for testing my pools re plumbing ?
Then I shot compressed air in and saw the bubbles rise
That damn # 2 and 3# crack at the branch ...
Believe it or not if you clean them very well i.e. lacquer thinner and then duct tape them close flush, they will seal up very well for a short test...
Good luck
Regards
Ed
Good luck
Regards
Ed
