It's alive!! My 3.3l
Old 07-17-2016, 01:15 PM
  #121
PF
PF's Avatar
Originally Posted by 333pg333
That would explain small injectors and able to use just the one 044 pump. I mean, as compared to a 3.3ltr running E85 which will use a lot more fuel than petrol. While there are a few things you need to change to run E85 it really isn't a problem...except some varieties of E85 can gum up the inj's. Ironically, mostly the supposedly Race Grade E85 vs the stuff out of the pump. Never had a problem with pump version but with the race stuff, we keep 2 sets of 2000cc injs and just clean them each time they come out.
Patrick.
Maxxtuning that manufactures MaXX ECU here in Sweden used to have issues with injectors clogging up when tuning cars on E85. They then started using this product http://www.maxxtuning.se/produkter/o...medel-i-tanken and since that no more issues. Maybe a thing to consider for you E85 users. Supposed to put one of those bottles in the tank every oilchange.
/Peder
Old 07-17-2016, 07:31 PM
  #122
rlm328
rlm328's Avatar
Y'all probably have better QA/QC there. Here E85 means that ethanol will make up no more than 85%. In actuality it runs anywhere from 45% to 65%. To run E85 I was advised to blend it my self for best results, this was a hassle I could do with out. I was looking at getting to sets of injectors, but in the end decide to use gasoline.
Old 07-17-2016, 11:11 PM
  #123
dizzyj
dizzyj's Avatar
I see your running dual 44s with a surge tank right? Hope the Fuelab works out, it cost me a ton
I'll say that I think e85 already saved my motor by being very forgiving while going lean. Definitely want to keep running it although will stick to pump. Race e85 is 9$ a gallon vs 1.50 at the pump. I'll just keep the timing conservative. Should have unreal power regardless
Old 07-17-2016, 11:40 PM
  #124
David Floyd
David Floyd's Avatar
I use this handy device to check my local $1.50 pump E85....works really well
Old 07-18-2016, 02:40 AM
  #125
333pg333
333pg333's Avatar
Originally Posted by PF
Patrick.
/Peder
Thanks Peder. I have sent them an email to see if they will ship to Oz. :-)
Old 07-18-2016, 02:49 AM
  #126
333pg333
333pg333's Avatar
We run 3x 044. Two in the spare tyre well and one underneath the car. I've heard the Fuelab pumps are good. Yes, the race E85 is crazy expensive but we don't drive the car much so it's not worth compromising. lol at $9 per gallon...if only we could buy it that cheap. Costs me $765 for 200ltrs inc shipping. That's about 52 gallons or $14.70c per gallon...Ouch!!
We also have an ethanol sensor in the fuel system setup. Put that in before I decided to go with the Race stuff. You can then run this through the ECU and adj timing to suit. Might be worth investigating that for your car?
Old 07-18-2016, 05:00 AM
  #127
odonnell
odonnell's Avatar
Flex fuel is really easy to add, most ECUs have a sensor input for it. It will interpolate tables, for fuel trim and spark advance. You can also use it to monitor fuel temp (coming out of the rail). I ran one in my NA car as an experiment and it's going to my 951 now.
Old 07-18-2016, 01:41 PM
  #128
Adonay
Adonay's Avatar
When i ran E85 i was living in sweden and had it everywhere. The mix blend was inconsistent at best since i am running a VR MAF system i had to deal with FQS all the time and rarely open the ecu to change the map. I gave up for a bit and bought 204Ltr Racefuel Ignite E85R, wow what a difference dead on 85% and tune once. cost allot though about 710USD
Old 07-18-2016, 03:39 PM
  #129
dizzyj
dizzyj's Avatar
I plan on adding a flex fuel sensor for this reason, but first I need to get enough fuel to the beast before I worry about the quality of the fuel.
Old 07-18-2016, 06:53 PM
  #130
blown 944
blown 944's Avatar
I would wholeheartedly disagree with that assessment. I've tested the ethanol content in multiple states and haven't found anything like you're describing. Currently I'm in south Texas and the pump E85 is testing right at 85% consistently. Colorado was also very consistent depending on the season.
Old 07-18-2016, 10:12 PM
  #131
refresh951
refresh951's Avatar
I agree completely. I have gotten E85 at 5 different locations and found it to be very consistent.
Old 07-19-2016, 12:24 AM
  #132
dizzyj
dizzyj's Avatar
got the fuelab pump in today. flow sheet with it says that it flowed ~190gph at 60psi !! that should solve my delivery problem
Old 07-19-2016, 01:45 AM
  #133
333pg333
333pg333's Avatar
I was always under the assumption that pump E85 varies the ethanol % content based on seasons?
Old 07-19-2016, 01:28 PM
  #134
rlm328
rlm328's Avatar
From Shells Website:
How does Shell ClearFLEX work?
Shell ClearFLEX is comprised of up to 83% ethanol and 17% gasoline as required by strict US government standards, and is visibly clearer than gasoline. Shell ClearFLEX is the only alternative fuel that can provide you with the high quality you have come to expect from Shell. Try Shell ClearFLEX today
From Exxon's Website
Ethanol flex fuel (formerly known as E85) has between 51 and 83% ethanol with the remainder being gasoline.
From the gov't website
E85 (or flex fuel) is a term that refers to high-level ethanol-gasoline blends containing 51%-83% ethanol, depending on geography and season
I cannot find the Houston Chronicle article on E85, but it showed a significant variation in ethanol content in Houston between refiners.
Please note I was looking at doing this 1 1/2-years ago and QA/QC may have improved. I made my final decision on the recommendation of my tuner who is one of the primary ethanol tuners in Houston.
Old 07-19-2016, 08:56 PM
  #135
blown 944
blown 944's Avatar
In the colder climates, yes they go to 70%. Tha'ts why I mentioned season in Colorado. Down here, we don't have a cold season really , so it's consistent 85%.
I'm going off of my measured experience in 4 states.
Quick Reply: It's alive!! My 3.3l
