Help with M-Tune Installation and Rogue ECU
Gents,
I bought the M-Tune and Rogue Tuning ECU from a fellow rennlister. I want to confirm the installation:
In the photos below I assume that I solder as follows:
Map Sensor Has: Red, Green and Black Wires
Rogue ECU Connector: Red, Blue and Black Wires
1) I assume I solder red to red, green to Blue and Black to black?
2) Also, on the Rogue site it mentions a toggle switch on the chip board, any advice on that?
3) On the Rogue site it looks like the white wire on the ECU is for a wide band, is that correct?
Thanks as always Rennlisters, wish they had detailed instructions on their website!
Small Business Partner
Correct.
If you are going to hook up a WBO2 to the white wire and the MAP sensor to the remaining wires, then set the switches set to: Turbo, 28pin, WBO2 Ext., Disable, External.
Correct.
Correct.
Correct.
