recommend me a clutch kit/setup
After losing shifting ability while running, I replaced my clutch master and slave. I bled 3 different ways and couldn't get the clutch to disengage. I checked the inspection port and there was a good amount of movement....great. Looks like my pressure plate isn't functioning.
Now I'm looking into clutch kits....
Zims has the cup clutch kit for $550. How much tq can it handle? I'm going stand alone soon and would like to be able to hold 375-400wtq if I wanted.
Any comparible or better kits out there for the price?
Thanks!
Thanks!
Basic Sponsor
Kep Stage I and 930 disc, talk to Jason at paragon parts
Basic Sponsor
1 Post
A properly installed cup clutch will hold 350-400 whp all day unless you are aiming to drag.
Very few 951' make a true 400 whp on a mustang .....Dynojet numbers are inaccurate vanilla sky promises
951's are notoriously over clutched with ridiculous 6 pucks and other associated non sense
best combo is if you are shooting for big up/TQ numbers use a cup pressure plate and re face your existing disc with organic / feramic by Southbend
I'm going standalone and twin scroll bigger turbo....shouldn't have a problem hitting 400, but don't really have a need to go that high...just in case
Where can I get a cup pressure plate?
Basic Sponsor
What would be a good clutch disk in standard turbo S pressure plate and fylwheel but in 600whp range?
Ak - +1 on the KEP pp and 930 disk here. Pretty much stock pedal feel. I'm putting down a little over 300whp/wtq. Stick with the stock flywheel if you go with this combo (I had mine lightened to 9.5 lbs and dig it, others not so much).
Im running the spec stage 3 both PP and disc. Ive seen a few bad reviews on the spec discs here but I have had no issues at 310whp. I got the car with the same kit and I replaced with it so I cannot comment on pedal feel that kit is what I am used to
Using the 7.5lb billet FW btw
