Tranny Mount Noise Comparisons?
#46
I did 60 on mine (diy urethane mod) and no complaints. Power to road improvement/drivetrain slop was noticeably improved. I think solid mounts are overkill. The transaxle feels rock solid, does not sway (like the old worn out mount did). This is on a car that is 75% autocross/track.
In terms of increased NVH, I didn't notice much change from worn OEM mount to diy urethane. Not having the rear carpet and padding on the back deck does more to increase trans noise than anything else, Ive noticed, as I do not have rear carpet or padding in my car
#47
Everyone who has done the 60 is happy with it while a few who have done the 80 have complained about it and either lived with it or redid it in 60 so I suppose 60 might be the better choice. I'm just worried about any transaxle movement at all because the reason I'm doing this is due to my CV joint pulling apart twice (once on the old axle and again within 5 miles of replacing with a new axle.) From what I've read, some have said that the transaxle will move with a new OEM mount but I'm not positive about this as was a small sample of folks IIRC or maybe they meant with the old, worn mount but I'm almost certain they said new.
But your statement that the 60 is firm enough to keep the trans from swaying or moving is great to know!
#49
Where'd he go?
Still gets email probably.
Unless...?
Which I hope not....
I hope he's ok.
Not sure what this means but useless in every way....
Lots of people have done this mod on this car with the exact products I have questions about and who are in this very thread (among others on Rennlist) so not sure why you would suggest I 'poke' around the internet unless poking is your thing.
Geez, when did the 951 forum become like the 986 forums?
Sorry but I don't understand the attitude when I ask a relevant question about an ongoing process that I'm trying to decide on and was hoping to get some useful information so I can get my car back up and running. Also, the fact that this thread is a few years old is helpful because these folks who have done this mod will have time and miles and can give me information that is very advantageous in which urethane to use. And there are many people in this thread who are still active. So what's the problem then? Would you rather I start a new thread?
Unless...?
I hope he's ok.
You're obviously new to these parts and it appears that you "can't read between the lines" when given a couple of clues.
I've not got any direct experience with this modification - but I may implement it.
#50
Rainman
Nice comparison and very surprised there is such extreme difference between 60 & 80! Makes me want 70 which of course is impossible to find!
Still, the 60 above seems way too soft to me, softer than the rubber usually used in any motor or trans mount. And the 80 seems like hard plastic. One thing to note is that there are different shore scales which don't align with each other but I assume these are both Shore A? However, I'm guessing sometimes people may confuse the two scales as sellers will list them right next to each other and a Shore 80D is much, much harder than Shore 80A, in a completely different ballpark actually. See the attached image.
But I'm wondering about any updates from Tom or others about which hardness they used and how they feel about it now and how it's held up...? Still not sure which one to go with, maybe the 65 I've seen somewhere. I'm not so worried about noise but the 80 in the video seems way too stiff to me. But I also don't want anything softer than stock and the 60 seems much softer.
Probably overthinking it all but any further info from those who have done this mod will be appreciated....
It’s an easy job, but messy. I did it for a few cars using 80A each time. I never noticed increased NVH but wasn’t really looking for it either. I do recall the marked improvement in transaxle “rock solidness” rather than worn stock mounts letting the trans sway wildly.
i don’t think there’s any harm using 60A here. It’s still better than a worn factory mount.
#51
Where'd he go?
Unless...?
I hope he's ok.
Unless...?
I hope he's ok.
Re-useless responses. Yes, there's some members here as well as other places you may "poke" around which are worth ignoring. Those people are incapable of providing any value to the community other than maybe some occasional comic relief, so it's typically best to just ignore and move on!
#52
I am the one who made the often-used write up on this forum for this urethane mount mod.
Hmmmm, trying to decide which one to go with. The video seems to show a huge difference between the two hardnesses but if you think the 80A doesn't cause any unwanted NVH, I think stiffer is the way to go. I don't mind noise too much and I don't even drive this car that much anymore but was just afraid of trans droning.
Re-TM, just google C*rP*kes and you'll understand.
Ok, back to 944/951 life....
Thanks for help everyone and I guess I have until warm temps arrive to decide on a shore rating as this is what I'm dealing with presently:
#53
Correction - I dug back into my receipts and I ran 80A urethane - ignore my post above about it being 60A (cant edit unfortunately). Been running this mod for the last 3 years and its been great
25 cubic inches from McMaster Carr (#8644K11)
https://www.mcmaster.com/catalog/130/4202/8644K11
#54
Thanks again.
