86 944 turbo - intermitant starting issues
Make up a three way jumper. The next time you have a no start, remove the DME relay and install it. If the fuel pump runs, you will hear it. It is behind the passenger rear wheel. If it starts running, the new relay may be bad. If not, the pump is probably the issue, but you need to check the wiring.
Where are you measuring the battery voltage? I do not think the alternator is a suspect.
Make up a three way jumper. The next time you have a no start, remove the DME relay and install it. If the fuel pump runs, you will hear it. It is behind the passenger rear wheel. If it starts running, the new relay may be bad. If not, the pump is probably the issue, but you need to check the wiring. Where are you measuring the battery voltage? I do not think the alternator is a suspect.
If the starter is turning the engine over, the alternator is not your problem,
Try cleaning the grounds at the rear of bell housing . Do the 3 wire jumper to bypass the DME relay .
Then if the fuel pump is running and it still does not start, look for ignition firing. cap , rotor , coil , coil wire etc.
