1986 951 need to sell
This didn't cost
me any drachmas
me any drachmas
I have an original 1986 951 with just over 93k miles on it and need to sell it quickly. Currently, the car has a bad clutch slave cylinder and the alternator is going out (whines). The car is located in Ohio and is garaged.
The car will need a new timing belt (don't have a record when it was last done) and the clutch, when the car was driveable, was starting to chatter.
I'm thinking pricing it at $5k (with the stock rims installed) would help with selling it quickly but wanted to ask my fellow Rennlisters their opinion before posting it officially.
Thanks.
Thanks.
Derek, sad to see you have to sell your car. I'd ask $6k and be prepared to take around $5k. Is there any way you can repair the slave cylinder and get the car mobile again? I ask because it might be the difference between getting $5k or $7500. Personally, when it comes to non-mobile cars, I always make an offer like the car will never move again so I don't get burned if it comes true.
This didn't cost
me any drachmas
me any drachmas
I can try to replace it and see if I can successfully bleed the system but even if I did fix it I'll still need to sell it low for a quick sale. The routine maintenance needs to be factored in, imo, even without the current issues with the car.
This didn't cost
me any drachmas
me any drachmas
This didn't cost
me any drachmas
me any drachmas
This didn't cost
me any drachmas
me any drachmas
Sold! Thank you, Ryan, and it was a pleasure meeting your dad and yourself today as well as selling it to an enthusiast.
Quit Smokin'
In case anyone references this thread, jack has a bunch of nice parts remaining, at reasonable prices. I didn't see anything that wasn't nice and priced to sell. If I was more liquid now I would have tried to buy it all.
Good luck with your move!
This didn't cost
me any drachmas
me any drachmas
Hey, bro!
17" CCW's 23mm's (early offset), 17" x 9" (255/40R17) and 17" x 10" (275/40R17) - they're in excellent condition, the ires have ~ 5k miles on them but are about 5 or 6 years old - $1,100 (can't ship)
18" Carrera 2's (pretty sure the original tires are on them, they're in fair condition) - $400 (can't ship)
B&B 2.5" SS full exhaust (cat-delete) with all of the gaskets and mounting hardware (bought those separate from LR - can't ship) - $700
Bilstein F/R shocks (were on a track car for one season) - $200
Lart's hard pipes - Kokeln Racing IC Hard Pipes - $250 shipped
SS fuel lines
Shark kit (I think that is what they're called, it's the custom battery grounding kit - it's the red/black ExFlex version)
Momo steering wheel with mounting hub
NGK spark plugs
Bosch cap
Rotor
Used K&N drop-in filter (looks like I had cleaned and oiled it at some point the past) - $15
Clutch Master Firewall Reinforcement - $90
951 Coolant hose, the "T" shaped one, BRAND NEW, PN 95110624702 - $15
MSD high vibration blaster coil - $60
Bailey's Performance diverter valve - make an offer
LR boost enhancer (nib part # LRA-951-TBE) - $90
LR radiator drain kit (nib part # LRA-944-RDK) - $25
LR vacuum hose kit "red" (nib part # LRA-944-VAC-RD) - $35
LR 8mm high performance ignition wire set (nib part # 09-566)
SS fuel lines
NGK spark plugs
Bosch cap
Rotor
Hey, bro!
18" Carrera 2's
B&B 2.5" SS cat-delete exhaust with all of the gaskets and mounting hardware
Bilstein F/R shocks
Lart's hard pipes
SS fuel lines
Spark plugs, cap & rotor, aftermarket performance coil, used K&N drop-in filter (will need to cleaned and oiled)
I have some more stuff but will need to go through several boxes to refresh my memory.
18" Carrera 2's
Bilstein F/R shocks
Lart's hard pipes
SS fuel lines
Dibs on the exhaust.! Let me know what you want for it.
what performance coil?
This didn't cost
me any drachmas
me any drachmas
The coil is an MSD high vibration blaster coil - pretty sure I got it from LR's site.
