87 951 VEMS Install
Old 06-10-2019, 01:44 PM
  #421
KVDR
KVDR's Avatar
I hope it's okay to hijack this VEMS thread - it seems to be best single source I've found.
Four questions:
1. Is there a comprehensive guide out there for tuning? I have been searching the forums and web and only find bits and pieces.
2. The tach in my dash works perfectly except that it seems to 'slip' above 5000 rpm under boost and load. The engine continues to rev but the needle floats at 5000. VEMS seems to report correct rpm though.
3. Boost gauge in dash is erratic (bouncing around) during steady driving, but reports properly under boost - is this normal?
4. Cold idle needs adjustment - is there a guide on this? Idle is low (800 rpm and lower) on cold start even after adjusting screw in throttle. I still need to double check the ISV functionality, but starting was very difficult today at 8C.
Thanks guys!
Old 06-11-2019, 10:42 AM
  #422
Droops83
Droops83's Avatar
I recommend the HP Academy courses ( www.hpacademy.com ) if you have time, they are excellent. Also search Amazon for "Greg Banish," he has written some excellent books on tuning.
Was your tach working properly before? That sounds more like a tach or wiring issue if VEMS is reading it correctly.
My factory boost gauge did the same thing after installing VEMS---it now reads gauge pressure instead of absolute pressure. I'm OK with this so have not looked into it.
You will have to experiment with your cold cranking enrichment table in VEMS. I still haven't dialed in the ICV on my car, the ICV works well but my idle is high (~1,100 RPM, even with base idle/screw adjustment ~800.RPM). I have been living with it until I have more time to play around with it, too many other car projects! But my cruise and high-load tune are dialed in nicely.
Old 06-11-2019, 10:52 PM
  #423
V2Rocket
Rainman
V2Rocket's Avatar
if you have tuning questions specific to VEMS (functional) then ask in here and those of us with the ECU can chime in.
this is a good thread for posterity, probably should save the page to the vems wiki lol
Old 06-12-2019, 09:12 AM
  #424
Portly
Portly's Avatar
I haven't been following this thread for a while. When I bought my VEMS setup, the boost gauge was a "known not-working item". Can someone tell me what I have to do to enable that?
_Jeff
Old 06-21-2019, 05:26 AM
  #425
shortyboy
shortyboy's Avatar
i had a few ask about my 36-1 trigger setup. I bought the wheel from goingsuperfast.com and got the trigger mount and sensor off ebay.
Old 06-24-2019, 05:19 AM
  #426
shortyboy
shortyboy's Avatar
Could someone who purchase their VEMS with wasted spark system, post up the part number of the wasted spark coil pack? Also where each spark plug goes on the coil. May have found the solution to my issue. Thanks in advance.
Old 06-24-2019, 05:24 AM
  #427
ealoken
ealoken's Avatar
https://www.efi-parts.co.uk/index.php?productID=121
You can use this
Old 06-24-2019, 06:21 AM
  #428
H.F.B.
H.F.B.'s Avatar
Bosch Double Fire Coil 2x2 --> 0 221 503 407 or Hella 5DA 749 475 041
Old 06-24-2019, 07:43 AM
  #429
shortyboy
shortyboy's Avatar
Thanks! I purchased the same part, just wanted to be sure. Would you happen to know the part number of your spark plug wires? And also, which spark plug wire number goes to which poles on the coil pack. Thanks again.
Old 06-24-2019, 08:04 AM
  #430
DLS
DLS's Avatar
The coil outputs are numbered
shortyboy (06-24-2019)
Old 06-24-2019, 11:47 AM
  #431
Dave951
Dave951's Avatar
What did you use to mount the wasted spark coil pack in this location?
Old 06-24-2019, 04:25 PM
  #432
H.F.B.
H.F.B.'s Avatar
At home I had the rest of a 5/8” Aluminum Plate that I milled according to the measures of the coil. Then I drilled 4 holes through the housing to bolt it down.
Dave951 (06-24-2019)
Old 06-24-2019, 04:31 PM
  #433
Dave951
Dave951's Avatar
Slick Job. I like it.
Velozipedia (09-15-2019)
Old 06-24-2019, 04:35 PM
  #434
shortyboy
shortyboy's Avatar
Anyone know the part number of the spark plug wires included in the kit? Picked up a set of audi 5000 that would fit the coil side but would like the beru plug boots on the head side instead of the metal sleeves on the audi set.
Old 06-24-2019, 04:56 PM
  #435
DLS
DLS's Avatar
The kit that peep sells is with metal sleeves.
H.F.B and i modified ours with beru contacts.
I have pictures in the vems pnp forum on FB.
H.F.B. (06-24-2019)
Quick Reply: 87 951 VEMS Install
