87 951 VEMS Install
Old 05-01-2017, 08:56 PM
  #31
NCLA951
NCLA951's Avatar
I ran ran mine through the shifter foam, as the lead wasn't long enough to go through the firewall. It's still a bit short so I may lengthen it. There's only so much tail on the Bosch sensor side, and I wanted to get that connection inside, but on the VEMS side I might make it a little longer to accommodate my interior routing under the radio.
Originally Posted by running_cold924
Hey Sam, quick question, what hole did you use to run the plug connector for the wideband O2? Is there one big enough on the firewall?
Old 05-02-2017, 12:16 AM
  #32
running_cold924
running_cold924's Avatar
Ah! There's an idea! I did buy a cable lengthen the O2 sensor connector about 5 feet so this may work perfectly! Also how far after the turbo did you install the sensor? Is a foot after too close?
Old 05-02-2017, 12:30 AM
  #33
NCLA951
NCLA951's Avatar
I just went off of the LR pics, right where the main exhaust bends toward the WG dump installed bung there 45 deg upwards of level.
Old 05-02-2017, 01:19 AM
  #34
SamGrant951
SamGrant951's Avatar
I ran mine through the factory wiring harness rubber plug on the firewall. I didnt have much luck de-pinning the WB02 plug (its quite large to try and get through the firewall) so I just cut it and re-pinned with a new connector I bought after I pulled the wire through. I had plenty wire to route the cable.
Old 05-02-2017, 08:58 AM
  #35
running_cold924
Okay, so at least 2 good options here, thanks guys. I do have a bung about a foot after the turbo for an O2 sensor and I already have a wideband (aem kit) on the main pipe bend under the car. I guess if the sensor doesn't last long closer to the turbo it'll get moved. I just need to get this car up and running, it's so rich right now with the maf kit.
So what are you guys using to run the VEMs? I did get the Bluetooth for smart phone connectivity but thinking I may want to get a small notepad or laptop dedicated to the car.
Old 05-02-2017, 10:13 AM
  #36
SamGrant951
I bought an Lenovo thinkpad X220 12.5", came with windows 7 pro installed, only cost about $150 on eBay, has bluetooth. Works perfect for this application, Peep recommended it. I also picked up an 8" Asus zenpad to monitor everything without laptop.
Old 05-02-2017, 12:20 PM
  #37
V2Rocket
Rainman
V2Rocket's Avatar
i just bought a bluetooth USB dongle for my small laptop that i use anyways.
Old 05-07-2017, 06:32 PM
  #38
running_cold924
Ok, got mine up and running today, it idles but surges pretty bad. Just up and down, up and down. It does staet way better so far. Where on the VEMs site is the app you download? I see they have nightly releases and stable releases...What's the difference?
Old 05-07-2017, 09:22 PM
  #39
running_cold924
Figured it out now I just need the pin. Nevermind, had an assist...
Thanks Sam for the help!
Old 05-08-2017, 03:45 AM
  #40
ealoken
ealoken's Avatar
Nice, standalone is great, i just got my 951 started yesterday.
But what ignition tables do you run ?
Old 05-08-2017, 10:59 AM
  #41
NCLA951
NCLA951's Avatar
I just run Raceboy's spark tables he sent with it, haven't tweaked them yet, but will when he is in LA tuning.
I used the latest stable version, haven't tried the nightly versions.
Re: idle surge, do you have an IAC hooked up and you're sure there's no air leaks? Could be a few things but working through all the idle options you might discover something. Any trigger errors?
Old 05-08-2017, 11:48 AM
  #42
running_cold924
Yes, still have the iac hooked up, was running fine on m-tune, no changes other than some plug and play stuff with the VEMs. It starts out smooth then about 30 seconds into startup is when the idles starts to surge.
Can you make changes with the Bluetooth or do you have to actually connect into it with the cable?
Old 05-08-2017, 11:58 AM
  #43
ealoken
ealoken's Avatar
What Does your charge table And idle controll table Looks like
Old 05-08-2017, 12:02 PM
  #44
NCLA951
NCLA951's Avatar
You can do everything with the Bluetooth laptop connection.
Old 05-08-2017, 02:19 PM
  #45
running_cold924
Ok cool. Talked with Peep, gotta reverse the polarity in VEMs for the IAC valve, should fix the idle surge.
Quick Reply: 87 951 VEMS Install
