Quick Jack
Old 05-11-2017, 11:50 PM
teamcrossworks
teamcrossworks's Avatar
Default Quick Jack
I'm thinking of buying a "Quick Jack" https://www.quickjack.com/ to start working on my car. Does anyone have experience with using one on a 944? Curious if it will line up under the preferred lift points...
Old 05-12-2017, 04:53 AM
Voith
Voith's Avatar
Nice lift solution. I need something like that too.
Old 05-12-2017, 07:13 AM
black944 turbo
black944 turbo's Avatar
I have been thinking about the same thing. Looks very nice.
Old 05-12-2017, 10:34 AM
951and944S
951and944S's Avatar
Pegasus Auto Racing carries either that exact one or one very much like it.
The "buy" configuration lets you choose between an a/c powered pump or dc that will run off a portable battery boost box.
There is a video at their site showing a 911 being driven on and lifted,.
I am considering heavily to get one (I have a full auto lift in race shop) just to bring to the track.
Come off track, pull onto lift just to change/rotate tires between sessions.
With scales and leveling pads, would make setup tweaks at track way easier too.
I say go for it.
T
Old 05-12-2017, 07:20 PM
darek_u
darek_u's Avatar
It looks really good, too bad it is not available in Europe. I would be all over it...
Edit: it looks like it is now available through UK and German site. Last time I looked at their site in 2016 they sold only on US market. Good news!
Old 05-13-2017, 04:36 PM
KVDR
KVDR's Avatar
This looks perfect to replace the two-post lift in the garage I've just moved out of. Wow, even free delivery within Canada!
I'm leaning towards the BL-5000SLX for the 5000lb rating - would better for modern cars which generally exceed the BL-3000SLX's 3500lb rating.... but first, I'll have to verify the longer frame length will fit the 944.
Old 05-13-2017, 05:25 PM
darek_u
darek_u's Avatar
Post the results when you have a chance. I'm also thinking about the 5000lb rated lift so I can lift up Benz and SUVs when needs be.
Old 05-16-2017, 03:45 PM
gruhsy
gruhsy's Avatar
Option B
20000 lbs capacity
Old 05-16-2017, 07:32 PM
teamcrossworks
Might not be such a bad option... lol
Although I was getting myself jazzed for the QuickJack option, I will likely spend that money elsewhere and go with a combination of race ramps and jack stands to get my work done...
Old 05-16-2017, 08:59 PM
shortyboy
shortyboy's Avatar
I have these works great on my lowered 951 with AIR lip.
Old 05-17-2017, 12:18 AM
numbskull
numbskull's Avatar
Those are great. I was looking at wheel cribs just to do simple under engine work. If you have a small garage it takes a lot of time to plan anything. It usually sux though.
Old 05-17-2017, 05:28 PM
marcoturbo
marcoturbo's Avatar
I have the highest wheel cribs from race ramps (12")
Even with a lowered car you can easily work under the car with a trolley.
Quick Reply: Quick Jack
