Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > DIYs and "How To" Archive > 964 (1989 - 1994 911)
Old 04-01-2007, 01:47 AM   #1
wsybert
wsybert's Avatar
Default Oil Change Procedure DIY
You will need the following:
* A large oil catch pan. At least 12 qts. (I used 2, a small one for the engine and a larger one for the oil tank.)
* A lot of rags.
* 15mm wrench
* Oil Filter
* 2 oil plug crush washers.
* Latex gloves (optional, if you like oil on your hands, because you may have to go fishing for your plugs or washers in the oil... ask my how I know.)
You will need to drive the car until fully warmed up.
This will open the thermostats for the oil cooler, and allow most of the oil to drain from the system.
Place the large oil pan under the oil tank. It is just in front of the right rear tire, about the middle of the shark fin and underneath. (See pictures).
If you are using the type of oil pan with the small hole in the middle of it, open the vent on the oil pan, and try to align the drain hole in the pan with the plug. It will limit the amount of splashing, as the oil will go straight into the pan first.
There are two ways to get most of the oil out of the filter and filter housing.
1) Punch a hole in the top of the filter with a screwdriver. (Sounds bad, but it works well)
OR
2) Loosen the vent on the backside of the oil filter housing (see pictures). I think it is 17mm, but I did not use this option. It is located up and behind the right rear tire, in the fender well.
One of these options will allow you to get most of the oil out of the oil filter and housing, by releasing any vacuum and allowing it to flow to the tank.
NOTE: If you use option one, you can tape up the hole when you are done draining the tank, so when you unscrew the filter it won't cause a mess.
Open the oil fill cap, as it will let air into the system to help drain.
Next, loosen the oil tank plug. It's 15mm.
There will be A LOT OF OIL coming out of the tank. So be prepared.
I put my oil pan on a towel to limit the splashing on my floor.
I am guessing there is about 8-9 qts in the tank.
NOTE: The oil is going to be HOT! So be careful. The latex gloves give you a little insulation, so it's wise to wear them.
NOTE: I had to jack up the right front a little to get my pan under the plug, and get a wrench on it. My car is lowered.
Next, you can drain the engine.
The engine oil drain plug is located on the left lower part of the engine. (See pictures)
It is the same size as the oil tank plug, 15mm. Unscrew the engine oil plug and drain the oil. Will be about 2-3 qts.
After both plugs are out, I let it drain for about ½ hour.
Now it's time to put the plugs back. I did not use new crush washers, and there are no leaks. Your choice. (I just forgot to order them.)
Torque to 50 Nm (37 ft.lbs).
NOTE: Both plugs have magnetic inserts to help in capturing metallic parts that are in the oil. I cleaned my plugs with carb cleaner to get any metallic particles off of the magnets.
Tape up the hole in the filter if you used that option, or tighten the vent back.
Unscrew the oil filter. I was able to unscrew mine by hand. You will want to place a rag under the filter to stop any oil from running down the inside of the engine compartment.
Apply a light coat of new oil to the new filter seal and screw it onto the housing. I tightened mine by hand as tight as I could get it.
NOTE: Make sure the filter housing has no seal on it. I have read and heard of the seal from the old filter sticking to the filter housing and you end up doubling up on the seals with a potential for disaster.
Now add your oil.
Oil filler cap is next to the filter, on the right side of the engine compartment. (See pictures)
Add 7 quarts of oil and then start the car.
This is a key part. You will not harm you car by adding only 7 quarts. If you try to add more, there is a good change you will overfill.
I let it idle for several minutes and then started adding ½ quart at a time, until the oil level gage began to move. Then added enough to bring the gage to the halfway point.
The car will need to be on level ground and fully warm at an idle.
I ended up putting in 11 quarts exactly.
Marc,
Thanks for the suggestions and additional info.
Anything anyone wants to add or any questions, let me know.
Bill
1999 E46 328i BMW (track toy)
Rennlist and PCA member
2008 Ford Explorer (again)
2004 Nissan Quest (wifes kid hauler)
1990 C2 Targa (gone ) (but always looking...)
wsybert is offline
Tags
1994, 964, cap, catch, change, chnage, diy, e46, filler, large, nissan, oil, oils, pan, pictures, quest, r1100s, seal
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
