classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat     |
Sign in using an external account
Thread Tools | Search this Thread |
#1 |
Rennlist Member Join Date: Mar 2003
Changed my brake pads for the first time and wated to contribute the DIY instructions as I could not find them elsewhere. Parts needed ( if you decide to keep your wear indicators - which I decided not to use)
![]() Decided on Pagid Yellows ![]() Compressing the spider spring with some pliers allows it to slip out of the bottom retainer: ![]() Lift the spring and you can pull out the old pads with pliers or a screw driver ![]() I would have had a bit more to go - (minimum is 2 mm) bit there is always the danger of uneven pad wear as you can't easily see the inside ones ![]() You will have to push back the two pods on each side with screw drivers in order to fit the new (thicker) pads ![]() Squeeze the spider spring as before and hook it back into the bottom retainer ![]() Done - this should not take you more than 10 minutes a wheel (which includes raising the car and taking the wheel off). I did not install the wear indicators as my car did not have them. I would not trust them anyway. Better to check with the eye. I know this is somewhat of a lame post, however it's really that easy.
Frank P '06 Cayman S #777 PCA "I" ![]() '94 964 3.6T ![]() '10 Cayenne GTS |
#2 |
Rennlist Member Join Date: Feb 2007
Frank, you said you did not use the new wear indicators. So did you leave them off altogether or short the old ones to stop the warning lamp coming on?
___________________________________ 964 C2 coupe GP White. KWV3 coilovers, Full engine rebuild, RS clutch and flywheel, RS engine mounts, Cat bypass, Polybushed, Recaro Pole Positions, Schroth Harnesses, 4 pot rear brakes, ducts and cooling on front brakes, strut brace, Cup style floorboards, no soundproofing, RS door cards & lightweight carpet. Running report about my 964 |
#3 |
Steve,
I left them off altogether as they were already shortened out at the connector by a prior owner of the car. There were no BWI indicators on the car when I took the old pads out.
#4 |
it's really that simple. I did not bleed the brakes. It's not a requirement when you change pads, however I plan to do it every 3-4 months since the car sees primary track use.
The fronts are the same as the rears. The wear sensors just clip into the space between the two humps in the pad. Theoretically, you don't need to replace them if you have them unless you've run the pads down to where they have activated.
#5 | |
Burgled
Rennlist Member |
Quote:
jim Conservatives....We work hard so you don't have to It all makes sense now. Gay marriage & marijuana being legalized on the same day. Leviticus 20:13- "If a man lays with another man he should be stoned." We were just interpreting it wrong. 91 White C2 Cab tiptronic 03 Black 996TT X-50 Grocery getter 2002 Dodge Ram 5.9L Gas Hog Bend-Pak Scissor Lift 64 230SL Mercedes (SOLD after 18 years )Some other Porsche's |
#6 |
Super User
What about bed-in procedures. Is that different for every kind of brake pad?
Last time I changed the pads I had read about a process of doing several runs (in a safe place!!) from 60mph to 20, or 10mph, back to 60, hard, near ABS down to 20, back up, back down six or eight or ten times; I forget. I do recall that these brakes are so good that I started to feel a bit like I had just stepped off a roller coaster! |
#7 |
Trial Rennlist
Member Join Date: Mar 2009
thanks for the info gents. Whats considered worn low? At my recent service they said my pads had 40% left in them and suggested changing them. I didnt see why they needed changing yet with that much wear left in them !
Mind you, and not sure if this was the normal service dealers ruse as ive heard it from so many people ripped off with it with other cars, they also said i should get the disks changed. Now im no mechanic but when i had the wheels off recently to tidy up my callipers the disks looked mighty fine to me. No scratches, pitting or other marks on the disk surface. There was mild surface rust around the top vented edge (not the disk surface) but that brushed off easily with a wire brush. So why would they apparently need changing? Should i now be suspicous of said garage? At any rate, it sounds like i can change the pads myself rather than paying them to do it, so this thread has been very useful to me
#8 | |
Mark, you're fine. The minimum pad thickness is 2 mm so anything above would not need replacing. Just keep in mind that my right side wheel was 4 mm and the left wheel 2 mm so they did not wear evenly in my case.
With respect to bedding in, here is an excerpt of what I found. Not sure how to do this on a public road: Quote:
#9 |
Rennlist Member Join Date: Aug 2003
FYI, the 2 pot calipers (rears on MY1991) are slightly different and require you push out the pins on either side. Pelican parts has a good writeup on this however so you're well covered:
http://www.pelicanparts.com/techarti...brake_pads.htm Frank, I don't think you can have too many write-ups on anything DIY related. Great thread! |
| Tags |
| 2002, 3500, 911, 997, brake, caliper, change, dodge, gt3, mm, pad, pads, porsche, problems, worn |
