964 Forum 1989-1994
964 C4 Widebody: 4.0L project
Old 12-26-2017, 11:36 PM
azmurciev12
azmurciev12's Avatar
that interior is gorgeous.
Old 03-22-2018, 08:39 PM
Rainmaker
Rainmaker's Avatar
Engine assembly about to begin. Parts from different suppliers have arrived.
- JE Engineeiring pistons and cylinders
- ARP bolts
- Carillo connecting rods
still waiting for the ITBs and cylinder head sent out to Xtreme Cylinder Heads
more pics soon!
Old 03-23-2018, 01:22 PM
SR20Fastback
SR20Fastback's Avatar
- ARP bolts
more pics soon!
Wow, coming along nicely! I've only recently learned that Rothsport is only like a 5.5 hour drive from my house. I have a feeling they may be getting some good business from me in the not so distant future.
Old 03-23-2018, 01:53 PM
Rainmaker
Rainmaker's Avatar
These arrived as well:
Old 04-07-2018, 11:33 AM
rsabeebe
rsabeebe's Avatar
Fikse Fuchs looks awesome!! Are they on yet?
Old 04-07-2018, 12:07 PM
Rainmaker
Rainmaker's Avatar
It’s in the garage. The tires just arrived. The car is still in the shop having all the bits and pieces installed. Waiting for,the engine to get back from IAP Racing.
In in the meantime these just arrived at IAP
Old 04-07-2018, 12:25 PM
FlyingDutchman
FlyingDutchman's Avatar
Great build! Where did you find the shifter ****?
Old 04-07-2018, 12:47 PM
Rainmaker
Rainmaker's Avatar
I ordered it from a guy called Chris at NASIOC, a Subaru forum.
Here’ a Ren list thread discussing it: https://rennlist.com/forums/964-foru...l#post11926352
Old 04-07-2018, 12:57 PM
wallra
wallra's Avatar
who make those itb's?
Old 04-07-2018, 01:02 PM
Rainmaker
Rainmaker's Avatar
Rothsport Racing or the guys that make it for them, I have to check my notes.
Old 04-07-2018, 04:43 PM
Moriartyhlms
Moriartyhlms's Avatar
Cool build. Could you give us some details on your engine plan? Bore, stroke, rod length, ECU?
Looking forward to see how it turns out.
Old 04-07-2018, 09:33 PM
Rainmaker
Rainmaker's Avatar
I’ve been asking Paul of IAP to chime in...
Here’s what I remember:
Syvecs 6 Plus ECU
45 mm throttle bodies
dual coil on plug conversion
LN Engineeering Billet Cylinders, 105mm, 12.5:1 compression
Carillo RSR Pro H 3/8 CARR Bolt Connecting Rod
Factory cylinder heads machined by Xtreme Cylinder heads, same guys who do cylinder heads for SingerRS Camshafts RSR Rocker Arms and Valve Control Set RSR Solid Lifters
Rothsport Racing Pulley/Damper
Old 05-11-2018, 03:02 PM
Jonte
Jonte's Avatar
Following...
Old 05-12-2018, 01:12 PM
jeff33702
jeff33702's Avatar
Can’t wait to see it
Old 05-16-2018, 07:44 AM
Raucky
Raucky's Avatar
Very curious to see how all this comes together and what kind of hp it makes. Great build and good luck, hope it all works out!
Quick Reply: 964 C4 Widebody: 4.0L project
