Battery Tender......
Standing by my post from 18 months ago. I now have three of these units and use them on Audi as well. Any car with a live cigarette lighter without a key in the ignition. https://www.ebay.com/itm/Genuine-Por...kAAOSwJ9Vdmk3T
The entire business end of the unit plugs in the wall and it comes with what seems like 30 feet of low voltage cable. This means I have no issue tending batteries on cars parked outdoors, as only the low voltage wire is exposed to the elements.
I use a BMW one. It's worked for years. All metal etc.. Looks like it's called the "Advanced Charging System" now.
Plugs right into the cigarette lighter to keep the battery fresh.
Even if you can't find the BMW one, I highly recommend one that charges right through your cigarette lighter outlet.
1.5 years later, I can vouch for my CTEK purchase. I bought three of them and have been pleased with their ease of use and performance.
kos11-12 (07-06-2021)
Piper_GT3 (07-06-2021)
I have 8 original Battery Tenders that are fantastic. A couple of them are the first ones that they came out with many moons ago. They are connected to British, Italian, German, and my John Deer.
+1 on the Battery Tender brand. I have had a cheaper brand that boiled my ATV battery dry. Since then, I switched to Battery Tender for my cars, tractor, ATV and motorcycles, I have never had any issues.
If buying a new charger now, buy the ctek that has multiple function for different types of batteries, as more and more replacement batteries are AGM type and require a special charger
I need get a new tender that can charge my RS and NSX at the same time. Anyone use this one? Looks good on paper.
https://www.amazon.com/NOCO-G4-Advan...s%2C196&sr=8-5
Battery Minders are rock solid. I have 6 or 7 of the 1510 model, some of which are over 10 years old. No issues, nothing to screw up while setting and the reconditioning works -- The last Odyssey in my RSA lasted 8 years.
CTEK is also good. I use a CTEK-7002 when a battery actually needs to be charged (the small Battery Minders will tender but not charge a battery).
