964 Forum 1989-1994
Window Express Install
Old 02-17-2018, 02:27 AM
Spokes
Spokes's Avatar
Default Window Express Install
I purchased a Window Express for $59 made for older 911s and VWs. Nice unit, no cutting of wires, just plug into the window motor & then plug in the wires to the origin window plug. Hardest part is pulling all the trim off. 90 minutes all up. I now have auto down / up and stop.
Old 02-17-2018, 05:41 AM
Dingo
Dingo's Avatar
That' a sweet little mod
Old 02-17-2018, 05:58 AM
rotorheadcase
rotorheadcase's Avatar
Nice work mate, been looking to do this for mine. Did you source it in NZ?
Neil
Old 02-17-2018, 10:09 AM
-nick
-nick's Avatar
Looks great- but I would suggest wrapping it in plastic. Rain comes right into the bottom of the door
Old 02-17-2018, 12:03 PM
Spokes
Spokes's Avatar
Thanks Nic, the box is well sealed, but next time I am in there... anyways, a fine weather weekend car
Old 02-17-2018, 12:22 PM
rkwfxd
rkwfxd's Avatar
I have these on order.
Old 02-19-2018, 12:58 AM
Poli84
Poli84's Avatar
I did this a while ago to my RHD 964 but struggled on the driver's door, to the point where I gave up and never finished the job. Did you have difficulty unplugging the OEM plug? I got the passenger side done no problem, but no amount of straining could get the driver's door disconnected.
Old 02-19-2018, 01:11 AM
Spokes
Spokes's Avatar
I did struggle to get the OE plug off the window motor. I couldn’t figure it out. After about 10 goes of pulling & wiggling the plug, shinning a light up through the speaker hole, using a mirror to see why it wouldn’t come off, I was left puzzled. I had one more go and just came off!!! I cant tell you what I did! I am installing another one this weekend in the pax door, I will try work it out and let you know if I discover the secret.
Old 02-24-2018, 03:53 AM
Spokes
Spokes's Avatar
OK, I did the passenger door today. I gave the wires themselves a gentle wiggle & pull (spade connectors often corrode themselves on). Then gave the main connector a pull and it came straight off the motor.
Old 02-24-2018, 06:01 AM
warmfuzzies
warmfuzzies's Avatar
Linky?
Thanks.
K
Old 02-24-2018, 07:13 PM
rkwfxd
rkwfxd's Avatar
Originally Posted by warmfuzzies
Linky?
Thanks.
K
Here you go.
https://www.paragon-products.com/Sea...indows&Submit=
Old 02-25-2018, 06:30 AM
warmfuzzies
Fab, Thanks.
K
Old 02-26-2018, 10:20 AM
freedman
freedman's Avatar
Or here from Amazon
Amazon Amazon
Old 02-26-2018, 12:58 PM
Spokes
Spokes's Avatar
Originally Posted by freedman
Have you installed the one from Amazon you have linked? It is not the same unit and the connectors wont fit.
Old 02-26-2018, 01:05 PM
freedman
freedman's Avatar
No, but the unit does the same job. Just need to deal with the wiring
Quick Reply: Window Express Install
