What's it worth? 1991 964 C4
1991 C4 with 92,000 miles on it.
- 2nd owner bought in 1999, with 30,000 miles on it. Has put 62,000 miles on it.
- Normal service performed but nothing above and beyond. Motor has not been taken apart.
- Need's AC upgraded or repaired. Works during summer months but needs recharged each year after the summer season
- Need to replace air duct mount on top of fan housing. (yes the picture does show duct tape and I'm sure some of you will cringe)
- Engine does drip oil and as owner says ( I agree) it's not enough to bother with.
- I would say mechanically it was taken good care of, but it was not pampered.
- Paint is 8.5 to 9 / 10. normal paint chips on hood. one wear spot on the rear deck lid left side. couple of minor chips and scratches which I think is normal for 27 year old car.
- Interior 9 / 10. Driver seat shows wear and tan carpet shows normal wear and tear.
- 0 rust.
- Everything else works great. lights, sunroof, stereo, power seats, etc.
- Red with Tan interior.
Likelihood is it will trade btw 40-45k
What's it worth? You have to add in what you will put into it.
I'm going to say to make it a good car, if you are going to have a shop do the work, you will be 10k min. If you like it and just drive it, a lot less obviously. But little fixes and parts add up fast. If you want it to be really good, add another 10k.
Last red C4 i saw sell went for 36k. Prices are up a bit. I wouldn't go over 45k...but if you keep looking you'll find another at 40k.if it's under 40, just pull the trigger.
I can't speak to whether it's a good car- pay close attention to the ppi. And make sure the car is leaked down when hot. Cold compression tests mean nothing.
Here's some recent BAT auction results to give you an idea on market value. Keep in mind coupes bring a significant premium. I have to admit some of those values are softer than I expected.
https://bringatrailer.com/porsche/964/
In general looking at historical figures requires a step back and more time to research why a car may have sold at a given price. For example very recently a Targa on BAT didn’t meet reserve. Seller failed to disclose that the speedometer stopped working in 2006 and was replaced earlier this year. Who knows how many miles were actually driven. In addition the car didn’t have the engine reseal done or any suspension work, that alone amounts to about $18 - $20K depending on what needs to be done. So pay attention to every detail, read the comments and evaluate your purchase from a perspective of what it will cost when you’re done updating (assuming no updates).
964 values on BAT are totally off, for some reason almost every 964 that goes on there has some type of issue or the seller is being vague & non transparent leaving doubt. Just like Afshin above said, That red 964 Targa with 50k will mess up 964 values if people just "browse" at it and dont understand the seller failed to disclose odometer hasn't worked in over 10 years.
To me this picture says a lot. It is a simple fix about $60-70 for a new rubber boot that someone has used gorilla tape to repair. When I see things like this I make an assumption about whatever other maintenance has been deferred.
Doesn't matter how many owners all it takes is one bad one. Is it a late MY 91 or early. Without further details it is hard to opine on price it can be anywhere from $35k to $55k depending on records condition, originality etc.
^^^ Bingo. If an owner will scrimp on the little stuff, they will certainly scrimp on the big stuff. Reckon he hoped his buyer wouldn't bother to open the decklid.
Thanks Cobalt. Agreed, after meeting the guy in person he bought the car in 99 and is the second owner, I mis posted the car only has 70,000 miles on it. 40,000 miles on it in 18 years. He doesn't have the bank roll to keep it perfect but has done all the regular maintenance nothing more nothing less. Appreciate the feedback. The PPI should be the tell the story.
Best luck hope it checks out. 70k miles will up the price a bit. Although only speculating I would have the paint metered. The front bumper has probably been resprayed the rubber smile is wavy and is usually a sign of paintwork and improperly installed. Hard to tell but the paint on the front end looks too good. Might have been resprayed as well also have the mirrors checked. The front smile is a mess and needs to be addressed. Headlights are fogged. Typical crack in the rear spoiler lid. looks to be a replacement windshield as well. You will probably want new rear tail lights which can set you back $1000 but that is cosmetic and your choice.
Not 100% certain but it does look like there’s some overspray on the front bumper trim, the hood alignment looks to sit back (usually extends just past the fenders in the front) and maybe some overspray on the rear fender flares rubber seals. Higher resolution pictures would confirm much of this.
Paintwork isn’t a dealbreaker, but it would definitely warrant further research to determine why it was done. At 70k miles it shouldn’t have significant road rash but it will definitely have some unless it was protected.
Good luck and post up what the PPI finds.
