964 big reds does it need a new proportioning valve and master cylinder
hi I am interested in purchasing big reds for only the front of my 964 c4 for now. When this is done do I need to swap out the proportioning valve. Or run an adjustable proportioning valve to correct the brake bias. Also will the stock master cylinder be able to accommodate the calliper singer piston size? Or will it have a terrible feeling brake pedal? Anyone that has any experience in this there opinion would be greatly appreciated.
C4 comes w/ a 23.8mm m/c oe this will be fine, though you will get much better feel from using a 25.4 from a 964RS
I'm running big reds up front and 993's in the rear, stock C2 MC and brake booster. Gutted the P/V. Pedal feel is pretty firm. Is it worth upgrading to 993 MC and booster?
stock 964 w/ 4/4 calipers has a pedal ratio of 46 .159, this is already poor
964RS(essentially what you have) is 32.786 when a 25.4mm m/c us used. This is excellent and right where you want to be for sporting use
stock 964 20.6 w/ the 964RS calipers(again essentially what you have) is 49.651 again poor and borderline inadequate, issues will arise in panic stops @~50 or higher
the best you will be able to get w/ vacuum boost is to use the 993 booster and 23.8mm m/c, that will give you 37.342 ok but nowhere near as good as the true RS set up.
If you think that is good then you have an eye opening experience awaiting.
Also, I see a couple of versions of the 993 mc and booster for sale from various internet outlets. Does buying from a place like Sunset Porsche ensure that I'm getting the best quality OE product? If not, where should I buy from?
Thanks Bill. Just to confirm, I can't simply get the 964RS 25.4mm m/c and booster to achieve optimal braking as you mentioned? Is the limitation availability? price? compatibility?
You'd have to t'p the whole setup, a non trivial task
I'm still waiting for someone to do a DIY.... I'd like to do the conversion one day but I think if I tried to pioneer the effort I'd end up deterring more than Id encourage.
I have big reds on the front of mine with a 993 mc, a gutted pv but still only the 964 4 pot rears. I know I need to get the early 993 rears to improve the bias as the car still has too much front bias. Rather than finding 993 rears is there another caliper that would bring the bias even closer to that of the rs. I know the 993tt will fit but at the expense of the handbrake which is a no go but could I get it to work with some custom made discs for the rear? I've found somewhere that can make whatever I ask for but that's the problem, I've no idea what I need!!
the 993 vacuum booster and 23.8mm m/c is a straight forward t/p
you need
993 355 910 00 m/c
993 355 023 10 vac can
993 355 301 00 gasket
993 355 163 03 m/c support
the hardest part is bridging the 12mm 993 fittings w/ the 10mm 964 lines
one way is to use Fedhill M6-3 - 12mm x 1.0 male steel nut with non-threaded lead - SAE flare or DIN flare
another is to have new lines fabricated 12mm on the m/c side 10mm on the chassis side
another is a BMW adaptor 34-32-6-752-405
and yes even w/ the 30/34 the p/v ought to be removed or gutted
