964 Forum 1989-1994
clutch disc compatibility
Old 10-04-2018, 09:44 PM
doruiacovescu
doruiacovescu's Avatar
Default clutch disc compatibility
Hi!
Clutch disk SACHS 1864 000 141
Numéro OEM: 99611601501
is it compatible with 964 c4 1990?
Regards
Doru
Old 10-05-2018, 09:42 PM
Spyerx
Spyerx's Avatar
Received 1,733 Likes on 1,061 Posts
i don't think so.
Old 10-06-2018, 04:52 AM
doruiacovescu
The flywheel from the kit works on 964, but i don t know about the disc. Found a nice price on this combo on ebay, the seller claims to work on 964, but i don t know nothing about the compatibility of the disc.
Any help would be greatly appreciated.
Regards,
Doru
Old 10-06-2018, 11:54 AM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Avoid buying new parts from anyone on eBay. Not only does the buyer not know what they are getting, the sellers don't have a clue about what they are selling.
Old 10-06-2018, 12:14 PM
Spyerx
Spyerx's Avatar
Is this a light flywheel sprung disk? If so. The clutch may work with the right pressure plate and throw out bearing when used with the light single mass flywheel. My car has the 997gt3rs 40 setup. The flywheel in my gt3rs is same 964 part number.
Old 10-08-2018, 08:06 AM
doruiacovescu
Hi!
Thank you for taking time in answering my question! I have double mass flywheel on my car. Should i stay away from this kit?
regards,
Doru
Old 10-08-2018, 12:32 PM
sooner964
sooner964's Avatar
Many people have moved from a double mass to single mass flywheel as a performance upgrade. However, it introduces issues with engine stalling at low RPM. This can be solved with a new ECU chip, such as the ones Steve Wong sells. I myself am still on a double mass flywheel.
Old 10-08-2018, 01:52 PM
doruiacovescu
I m also keeping the dmf, but i m curios if the clutch disc is compatible with my setup
Quick Reply: clutch disc compatibility
