Winter is coming- what's the project?
#46
Dropping the engine for a 6 speed / rs flywheel transplant. Reseal as needed lots of small stuff while it’s out. New motion control dampers,rs carriers 993 brakes of some flavor, booster etc.... Need some seats as well. Love to add electric power steering as well but I’ll be doing well just to get this much together by April.
Doing the work with my mechanic- he’s cool about guiding me the process and buttoning up the stuff I can’t get too. I’m good at spending way too much time on details.
Pete
Pete
#48
IHI KING!
Good topic Rob. My cars hibernate for the winter.
On my cabrio, I will be working to remove and replace one of the roof header cam locks. The gearbox appears to be stripped in the closed position. It won't release even if I manually spin the motor. Not exactly sure how I will get the header to release. I may have to unbolt the rear pivot points so I can shift the roof rearward. If anyone has any advice, I would appreciate it.
On my coupe, I plan on removing my DAS roll bar and to sell it. The urge to drive on the track has waned. I had stopped DE events while our daughter was going through college. I prefer weekend drives through the mountains, so I will be pulling out the roll bar and selling it with the GT3 seats that I had planned to install.
Note: My DAS roll bar is sold.
#49
Not doing as much as preparing for bigger things.
0/ Drive as much as possible. My season for driving is Oct to May.
1/ Figure out if AFM is correctly functioning. I suspect the temp sensor not working well.
2/ Replace fire extinguisher.
3/ Get all parts together for cosmetic refresh inside and out. Not full respray, but new exterior seals (excluding window seals), source OE leather hide (that stuff is pricey).
4/ Find out what how to fix my gearbox - with help of my mech who has my original box. I am driving on my spare box. Get parts for fix and rebuild.
5/ Install dash cam.
The two big tasks are for next summer.
Enjoy the projects everybody.
#53
Winter List:
> Fitting your interaxle diff lock slave cylinder seals, Rob.
> Fitting rear reflector replacement grille from Andrew
> Buy garage scissor lift
> Get my head round the possibility of changing chain cover gaskets with engine in place
> Template and make up rear wheel arch liners
#55
I finally received my missing cylinder and the build is back on. Once the timing is done the fitting of the 993GT3 intake and custom throttle is next. Then the exhaust and garrett BB turbos.
#56
Making my cab top a manual, since one side is now inop.
#57
You have some wacky rules over there. You would think with the poor visibility of the brake lights this would be welcomed.
#58
Originally Posted by LM964
Winter List:
Also, if you stretch the seal and it feels too big - let it sit in a warm place and it'll shrink down. I thought once i had screwed one up, and a day later it was right and fit fine in the bore.
#59
The GT3 intake is usually used with ITB's. I am sticking with the low boost twin turbo approach I had as it will cost a bit less and HP and torque will be considerably higher over ITB's. I don't need to go the high revving route for track duty and the longevity should be greater. So far I have installed pauter rods, custom pistons, stronger valve springs and Ti retainers. The engine will be good for a reliable track duty 500 rwhp and torque. More than enough for a 2650 pound car. I am trying to save the weight over the varioram intake that was on the car before and the GT3 castings are cheap.
#60
That's awesome. Take some pics of the diff slave seal replacement. Watch the direction on the center seal and if you need any help feel free to get in touch and i can walk you through it...
