964 Forum 1989-1994
Pest proof storage techniques?
Old 11-04-2018, 02:12 PM
nowata
nowata's Avatar
Default Pest proof storage techniques?
Thinking of moving my cars out of my heated garage to free up space for a project
so so far I have an Unheated hangar which is not free of pests
thinking of a car cover and the. breathable cover than can zip closed
any other suggestions?
Old 11-04-2018, 06:06 PM
cjoenck
cjoenck's Avatar
Pest control?
Old 11-05-2018, 10:56 AM
Jacke2c
Formerly turbotwoshoes
Jacke2c's Avatar
Price a wiring harness and then calculate how much you will need to spend to prevent that. That, to me, is the #1 killer when it comes to storage where there are rodents. I had to replace my John Deere tractors harness from one month parked out at my barn. $$$ Its not a matter if it will happen, it is a matter of when it will happen. To quote Clint Eastwood "do you feel lucky?"
Old 11-05-2018, 12:01 PM
canuck964
canuck964's Avatar
Would this actually work or would the rodents just chew thru the plastic?
http://carcapsule.com/
Old 11-05-2018, 12:10 PM
tbennett017
tbennett017's Avatar
I have a car in a car capsule where there are definitely pests... and so far so good after 6 months.
Old 11-05-2018, 04:57 PM
azander
azander's Avatar
Before anything else, look at a storage insurance policy - comprehensive coverage with rodents included. Fairly inexpensive, just make sure the policy covers it.
Make a reasonable attempt to keep them out.
Old 11-05-2018, 06:28 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Tom Bennett's solution is very good for keeping out the pests that can positively ruin these cars.
A cat works well, too!!
Old 11-05-2018, 06:55 PM
canuck964
canuck964's Avatar
Another fully enclosed cover.
https://www.carbag.com/support/
Anyone have one of these?
Old 11-05-2018, 06:56 PM
canuck964
canuck964's Avatar
I wonder if I could just roll over a large tarp put on a car cover and pull up the sides of the tarp to keep out the mice?
I know the mice can chew thru the tarp but if there is no food odors why would they?
Old 11-05-2018, 07:10 PM
sb3
sb3's Avatar
I live out in the country where we have lots of critters just waiting to eat wiring harnesses. My brand new T250 van had 2k in damage last year from mice. I have found that puting an old radio playing softly (music choice is up to you) under the car will work and using Repels-All spray around the car keeps rodents away.
Old 11-06-2018, 02:01 PM
Four Liter
Four Liter's Avatar
For the last 2 years I've stored 2 different GT3 RS's in a Carcoon which while somewhat costly ( around $1600 ) I've had zero problems with mice which are present in the building I store my cars . Prior to the Carcoon it was a constant battle with older Porsches I owned . Make sure you keep the Carcoon a reasonable distance out from walls so that you can walk around it on a regular basis and to make sure no nests get built alongside it . The best $1600 I've ever spent .
Old 11-06-2018, 05:21 PM
RallyeChris
RallyeChris's Avatar
I've been using the ultrasonic devices for years without issue. One on either side of a 2 car garage. I also have a cat, though the cat doesn't go in the garage.
Old 11-06-2018, 05:59 PM
HDA
HDA's Avatar
Ha this reminds me when I took out my dads Lancia Flavia HF (ex race car, full straight exhaust and ITBs. Nope, not fulvia) and at the first 2nd gear pull (pretty loud as you can inagine) a freaking mice ran over my leg!
almost crashed that car as I freak out and try to get that rodent off of me.
i also suggest cats
Old 11-06-2018, 11:51 PM
Paolo1
Paolo1's Avatar
Scatter dryer sheets around the car and in the tailpipe. I understand they can not tolerate the smell.
Old 11-07-2018, 06:41 AM
Navaros911
Navaros911's Avatar
Used a Cairoport for 5 years or so in an old barn and it worked just fine.
As mentioned before, leave anough space between it and the wall. The model I used had permanent airflow from 3 fans, which may keep them away as well.
Carcoons with the external frame are the same product as what I had.
Good luck... I love seeing cars hidden in barns and warehouses... there is something special about pulling them out for a run.
Quick Reply: Pest proof storage techniques?
