964 Forum 1989-1994
Fikse ZFs - 17” Rear Wheels... 9.0 or 9.5 inches?
Old 11-24-2018, 12:59 PM
August West
August West's Avatar
Default Fikse ZFs - 17” Rear Wheels... 9.0 or 9.5 inches?
I’m ordering up a set of Fikse ZFs and was hoping for some guidance as to whether I should get 9.0 or 9.5 inch rear wheels for my narrow body 1990 C4? Is one better than the other for tire sizes? I’d also like the proper offsets so I won’t need spacers. I’ll be running 8.0s in front. Thanks in advance!
Old 11-24-2018, 02:51 PM
Bill Verburg
Bill Verburg's Avatar
Factory ran 205/50 & 255/40 on 7ET55 & 9ET55
You can run 225/45 on 8 ET50 or 52 & 255/40 x17 on 9ET55 or on 9.5ET47, this latter was used on 964 Cup.
W/ AWD the concern is matching f/r tire rolling radius
Old 11-24-2018, 03:49 PM
August West
Thanks for the reply, Bill. I suppose offsets are specific to particular wheels... the offsets for Cup 1s would be different from the offsets for Fuchs-style replica wheels. Is that correct?
Old 11-24-2018, 03:51 PM
August West
...and thanks for the reminder about F/R rolling radii on the C4... within 6% of each other IIRC.
Old 11-24-2018, 06:57 PM
Bill Verburg
The ET(offsets) is correlated to the wheel width and how aggressive a fitment you want.
For instance an 8ET59 is slightly more aggressive than an 8ET52, another example a 7.5ET45 is comparable in fit wrt the lip to an 8ET52
Old 11-24-2018, 06:58 PM
Bill Verburg
I'd need to look it up but I think that ABS spec is w/i ~5%, the envelope for AWD is tighter
Old 11-24-2018, 11:38 PM
rotorheadcase
rotorheadcase's Avatar
I used to run 8" front and 10" rear on my C4 but now run 8.5" in front and there is a noticeable difference with turn in with ess understeer so I'd opt for 9" rear for C4 if you have 8" fronts.
Neil
Old 11-25-2018, 02:22 AM
August West
Well I’ve ordered up 7.5 inch fronts and 9 inch rears. When Zuffenhaus had their webpage up, I remember them saying 7.5 inch for stock springs or 8.0 with 2.25” springs.
I’ll be sure to post when they arrive and when mounted.
Old 11-25-2018, 02:29 AM
August West
I found the 6% figure for rolling radius differential in Adrian’s book.
Old 11-27-2018, 03:40 PM
Atgani
Atgani's Avatar
The 9.5” Cup rear wheels will require spacers to clear the oil pipes in my experience.
Old 11-27-2018, 05:31 PM
Bill Verburg
The wheels used by the factory on 964 Cup were 9.5x17ET68, They used a 21mm spacer to provide an installed ET47, Yes, all Cups had a flattened oil line.
When the switched to 19s the 9.5x18 had an ET47, No spacer used.
when used w/ a 265/35 tire the 9.5 ET47 wheel has a backspace of 7.1"(180.4mm) though I have seen 10ET ET45 used w/ 275/35x18) wheel b/s is7.27"(184.7mm) this should be considered the max b/s that can be used on a 964, the 265 tire b/s is ~7.07"(181mm) a wider tire like a 275 would have a little more backspace
Old 11-30-2018, 02:53 PM
Atgani
Atgani's Avatar
Hi Bill, running the 9.5 x 17 ET68 Cup rears with a 21mm spacer leaves a lot of clearance between the tyre and fender. I think I ended using a 28 or even 32mm rear spacer to get the standard 255/40 rear tyres to fill the fender well out nicely. See attached images of my old car running this set up.
As I recall the C2 and RS run “unflattened” oil feed/return pipes.
Old 11-30-2018, 03:57 PM
Bill Verburg
I just reported what the factory did
Yes, the street cars ran unflattened oil lines, but they also used 9E55 w/ 255/40 x17.. This is strange because the 9 actually has a bigger back space than the 9.5
Old 11-30-2018, 04:13 PM
Bill Verburg
Here's a comparison of what was used on a 964 RS and 964 Cup
Old 12-01-2018, 03:29 AM
GoKart
GoKart's Avatar
Do you have to flatten the oil line with a 10” rear wheel, if you don’t lower the car too much....? Maybe a lower-than-stock-US-ride-height, but not-quite-RS-ride-height?
Quick Reply: Fikse ZFs - 17” Rear Wheels... 9.0 or 9.5 inches?
