964 Forum 1989-1994
Exhaust fumes smell inside when the heater is on!
Old 02-03-2019, 04:27 PM
rost12
rost12's Avatar
Default Exhaust fumes smell inside when the heater is on!
Hello,
As per the subject, on the recent longer drive during our British winter I had quite a strong exhaust/fuel smell inside the cabin. What are the usual suspects?
Old 02-03-2019, 04:45 PM
Vegas993
Vegas993's Avatar
Check the connection on the hoses that run between the heat exchangers and the chassis.
Old 02-04-2019, 11:24 AM
crg53
crg53's Avatar
I had the same issue, it turned out to be power steering fluid leaking into the right side heat exchanger. In my case it was the seal on the cam shaft that was leaking.
Old 02-04-2019, 11:40 AM
A914MAN
A914MAN's Avatar
If it was exhaust you'd probably be experiencing some health problems. Typically odors in the heat system are leaking fluids on our around the engine or exhaust system. I'll bet if your car was put on a lift and checked out, you'll find leaking fluid somewhere. 964 exhaust systems are stainless and very robust, and leaking exhaust gasses into the heater envelope is rare.
Old 02-04-2019, 12:09 PM
JohnK964
JohnK964's Avatar
I agree the exhaust may be stainless and robust the the hoses aren’t
Quick Reply: Exhaust fumes smell inside when the heater is on!
