Plug & Play Oil cooler mod
Spyerx (02-16-2024)
#79
Will take one as well. Doing front cooler fan refurb soon.
#81
You guys are responding to a three year old post.
#83
I got same message, same here (tried to PM @Kappi2907 but mailbox is full) would like to buy one if possible.
Thx
p.s. most of us know it's a 3 year old post but you can see the demand from these last week or so alone
Thx
Advman89 (02-29-2024)
#85
#86
You can actually build one of these pretty easily yourself if you can use a soldering iron. All you need is a couple of plugs, shrink tubing, and a resistor. The specs are on this forum. The original idea is brilliant and works really well.
#87
I found the thread with the resistor specs, 2.1k
https://rennlist.com/forums/993-foru...l#post16768217
MSQ (03-01-2024)
#89
Thanks again. Reached out to the OP in the thread above. He is not making them and has no plans to.
Does anyone have the specs, yea I know it's 2 ohm in line resistor, but by specs I mean:
- part numbers or links to the connectors on both ends in above pic
- part numbers or links to cable used to make it- part numbers or links to specific resistor (yes I know a 2 ohm resistor)
- basics of the wires inside the sleeve (i.e. where do they terminate on side of the connector//plugs)
#90
I believe the connector ends are
022 906 233 B
And
311 906 231 B
They are on illustration 902-58 page 696 of the porsche parts catalogue here
https://www.porsche.com/usa/accessor...artscatalogue/
MSQ (03-04-2024)
