964 C2 4.0L wide body lightweight rebuild
#467
Those are impressive HP numbers any info on torque? So you should be where I am with the 993 longitudinal using 100mm spacers which is a tight fit but should work.
#468
The cam is actually pretty mild and gives a really nice flat torque curve. I could have made some more top end hp according to Jeff, but was keen for the low down torque for drive out of the corners.
Torque peaked at 327ft lbs at 5,250rpm. But low down is good and it makes 250ft lbs at 2,600rpm and 300ft lbs at 4,250rpm. Should light up the tyres nicely
Antonov (12-03-2021)
#471
^^^ Very nice. GL and drive it in good health.
Greg Wolfe (11-10-2020)
#472
Reap Automotive in the UK did the tacho.
kos11-12 (11-16-2020)
#476
The following 8 users liked this post by 964.4L:
GentlemanRacer (11-15-2020),
Jacke2c (11-17-2020),
JasonAndreas (11-15-2020),
LimeyBoy (11-16-2020),
Sirenty (11-15-2020),
and 3 others liked this post.
#478
Such an inspirational thread. Enjoy in good health!
I might've missed the update on the electric A/C as I was drooling over the recent pics, but any feedback on operation yet? Did you install the second condenser option?
#480
Hence, if you have an aircon car, id save some money and just buy this kit https://www.classicretrofit.com/coll...essor-ecu-only,
Then replace the condenser and evaporator (just so you have new parts and avoid leaks etc) for the cheaper hella products on design 911.
But i have some electrical issues and aircon is not working yet. Apologies, but will report back as soon as its sorted.
BLACK3.2 (11-15-2020)
