964 Forum 1989-1994
964 C2 4.0L wide body lightweight rebuild
Old 06-12-2019, 03:28 PM
964.4L
964.4L's Avatar
Default 964 C2 4.0L wide body lightweight rebuild
Hi guys, I thought I would share my project. I have recently bought a donor car in April this year. Its a 1990 964 C2 manual….in good condition and pretty standard except for KW V3’s and a recent paint job. The engine is pretty tired with 130,000 miles. See some snaps below.
The current plan is as follows:
Motor – the only thing that I am retaining is the crankcase. Target is >400hp:
- GT3 4.0L (80.4mm crank), GT3 intermediate shaft, GT3 oil pump
- Carrillo rods
- Custom 102.7mm Mahle pistons
- Custom 102.7mm barrels
- Custom heads from Xtreme cylinder heads
- Custom cams
- Custom rockers and other head bits
- ITB and plenum
- Custom stainless headers, GT3RS muffler
- Motec
Clutch & gearbox:
- RS lightweight flywheel
- 993 turbo clutch
- gearbox rebuild
- Guards LSD
- Rothsport shifter kit with golden rod
Suspension & brakes:
- Retaining the KW V3’s at this stage
- 993 RS front uprights
- Transverse strut
- New bushes
- GT2/RSR inner steering tie rod, tie rod extension
- Front brakes: Brembo 6-Piston, 355x32mm rotors, 2pc Floating
- Rear brakes: Brembo 4-Piston 328x28mm rotors, 2pc Floating
Chassis:
- Full strip (every nut and bolt coming off the car)
- Water blast full chassis
- Sunroof delete, replaced with carbon panel
- Seam weld
- 965 wide body steel panels and bumpers
- RS rear window and wiper delete
- Half cage
- full repaint (colour TBD)
Interior:
- Still deciding, but will be lightweight, but still usable
The build just started last week. Car currently being stripped and motor is out (see some other snaps below). I have bought most of the long lead parts with a bunch arriving shortly. I will post photos as I go with the build.
Hope you find it interesting and open to any suggestions people may have.
Cheers
The following 2 users liked this post by 964.4L:
I am the Walrus (09-17-2019), Steve Theodore (01-30-2021)
Old 06-12-2019, 03:50 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Sounds like a fun project. Good luck and keep us posted.
Old 06-12-2019, 03:54 PM
964.4L
964.4L's Avatar
Thanks and will do. Although I will be pushing this forward as quickly as I can, it will take a while. Cheers
Old 06-12-2019, 03:58 PM
964.4L
964.4L's Avatar
Oh, I forgot to mention, if anyone is interested you can follow the build on Instagram on Porsche964.4l
I will be posting more photos and vids on there as well.
Cheers guys
jeff33702
jeff33702's Avatar
That looks like a sexy plan. It's almost EXACTLY what I'm planning over on this side. I've already purchased most of the OEM widebody turbo parts. I'm also going to take it down to bare metal. Project is probably a few months from getting started (although I've been collecting the parts I have for almost a year now). Somehow ended up with 2 G50 gearboxes...one is factory LSD with some miles on it and the other has NO lsd but is essentially new...so decisions
I'm curious what you're planning for the carbon panel sunroof delete. I have the metal filler plate for that but would consider carbon...I'd like to see some details on how others have integrated that.
You might find that 965 rear quarters are 1 - not really available used that often, 2 - like $3k per side new from Porsche.... I'm looking into what others have suggested - getting the dansk ones for a 930 and the fabricating the 965-specific attachment points.
Excited to see this one go!
motts (08-08-2019)
911Jetta
911Jetta's Avatar
Welcome, what a first post! This will be awesome to follow.
Are you coming from past Porsche GT car experience or have you owned a 964 before?
What colors are you thinking about??
Old 06-12-2019, 04:06 PM
964.4L
964.4L's Avatar
Thanks Jeff. I have bought the carbon roof in the UK and will share the details once my body guy gets it fitted. I have bought the full 965 rear quarters from Porsche. I am told the 930 arches are a pain to get right and the wide body shark fin doesn’t line up. So I bit the bullet and paid up.
Old 06-12-2019, 04:08 PM
964.4L
964.4L's Avatar
I have modified cars before. But first time for a Porsche. Been planning for a while, so thought I would share the story. Suspect there will be some real learnings along the way.
Have a few thoughts on colours and I know for sure it won’t be guards red. Thinking maybe chalk. But have some thinking to do
Old 06-12-2019, 04:15 PM
964.4L
964.4L's Avatar
BTW, keep us posted on your build. It sounds cool and keen to see what others do. Cheers
Old 06-12-2019, 04:20 PM
964.4L
964.4L's Avatar
Engine out first
On the engine stand ready to have all the crap stripped off. If anyone is interested in 964 engine bits (crank, barrels, pistons, rods, heads etc then please let me know)
Old 06-12-2019, 04:31 PM
SR20Fastback
SR20Fastback's Avatar
Cheers guys
Sounds like a fun, albeit expensive project. Just gave you a follow, can't wait to see how it turns out.
Old 06-12-2019, 04:52 PM
Sirenty
Sirenty's Avatar
Wow, that’s my dream build (and likely always will be just a dream). Following with interest.
Old 06-13-2019, 05:10 AM
964George
964George's Avatar
Subscribed +IG too.
Old 06-13-2019, 05:51 AM
964.4L
964.4L's Avatar
@964George where did you get your side rear bumpers made (without the hole for the exhaust outlet)?
Old 06-13-2019, 06:13 AM
Bruni
Bruni's Avatar
I know how expensive it's gone be if you do this by original factory parts as i did.
The following 3 users liked this post by Bruni:
I am the Walrus (09-17-2019), Jostein Werner (09-13-2020), Steve Theodore (01-30-2021)
Quick Reply: 964 C2 4.0L wide body lightweight rebuild
