Rear Reflector Substitution Panel V3
Here is a sneak peak of the version 3 of the Rear Reflector Substitution Panel. This version "V3R" will be a complete lightweight panel replacement specifically build for motor-sport use and to aid in cooling. It will not have the lights. Take a look.
Thanks!
Andrew
Thanks!
Andrew
The following 5 users liked this post by 964Andrew:
964George (05-24-2020),
JP-"S" (01-03-2022),
kos11-12 (06-09-2020),
maro (09-06-2022),
Patrik Rens (02-04-2021)
Looks well thought out! What is the material of construction for the red version?
Rear panel
Won’t help with cooling unless you go in and drill out section of the metal panel that sits behind. There is no natural open access to engine area through the metal cross bracing. The center light replacement is only visual unless modifications to the metal cross brace are made. My 2 cents. Looks cool though.
Second post from the top best shows the location and muffler proximity (https://rennlist.com/forums/964-foru...install-3.html)
Thanks!
Andrew
Black, Red acrylic, textured, glossy and solid are all considered as an option when configuring this panel. The back bone of all these variations is the frame.
Thanks!
Andrew
Thanks!
Andrew
The following 2 users liked this post by 964Andrew:
kos11-12 (12-22-2020),
