Help with Scantool – Test output feature
Originally Posted by JasonAndreas
You can just add those to the config file. All you need to know is the memory location inside the tip ECU...
I have a question. Has anyone been able to read any trouble codes with the tool? When I first used the tool I did not have the Steve Wong chip installed. I basically used for Adaptation and it seem to connect fine. Most recently I tried to use it to try and pull a trouble code but no dice and it takes forever to connect to Motronic or others. I'm curious who else might have a steve wong chip and is able to connect.
964Luftballoon (09-21-2021)
Technical Guru
Since the tool appears to read memory addresses directly, I could imagine that a Steve Wong or any other aftermarket chip may not work. Only way to really tell is use a data packet sniffer like Wireshark and compare data streams. I could be wrong of course but the tool works well for the oem chip.
