2nd muffler bypass
#31
I haven’t found mine to be too loud or annoying yet. I love the sound personally.
#33
Thanks everyone for keeping the conversation going. Once we get the discussion terminology straight, let's see if there is a difference and why.
In the posts above, looks like we've uncovered most of the names we associate with the J pipe. (swans neck, long g-pige)
We are talking only about deleting the secondary exhaust (regardless of what's happening upstream - like: cat bypass, primary bypass, etc.)
To that end, I'd love to know more about the sound characteristic of changing either the length, angles and maybe even the tubing diameter.
The j-pipe definitely sounds different that g-pipe. 100%.
I like the g-pipe, but it's definitely louder, deeper, and has a woof, woof Subi/Harley sound. To some, the sound is far from the traditional flat six sound. I don't dislike it, but for the reasons mentioned I'm struck by how much I like mine in comparison, and the main difference that I currently notice is just the length of the pipe.
I love my J-pipe bypass and if for whatever reason I couldn't use it any longer, I would switch to a primary bypass over a g-pipe bypass.
I always appreciate when people ask questions that promote a better conversation. We're all friends here.
Interesting that you call your primary a J-pipe. The majority on this forum would/should associate a primary bypass as a "Cup bypass". It was the factory exhaust set up for the Carerra Cup series, hence the common association.It's the Cup bypass (or at the very least a primary bypass, given where it is).
Exactly. It's a point others have mentioned many times on this forum. The g-pipe bypass is the loudest option. Many who have had one love the sound but in come cases it's too loud for their lifestyle.
This point is made more interesting by the fact that I also have a cat bypass, and it's still not overly loud with a j-pipe.
The j-pipe really shines when matched to a cat bypass. 10% louder (ie: slightly) but much more mechanical sounding. (!!!!!)
I've tried all the bypass combos also, and agree.
For me, no need to go with headers or anything else custom. Especially since these changes are cheap and easy to make (or reverse).
I'm taking just about choosing one bypass. That's what the majority of us would do, it's a simple and makes a big impact on the sound of the car. Either the primary or the secondary.
Thanks for asking that question. Yes, the j-pipe sounds that good. It's louder and more mechanical than choosing a primary bypass instead (which I had for years in another car and loved also).
When I bought this car I knew it had a secondary bypass and I thought I would be switching that for a primary bypass instead. I was very pleasantly surprised when the driver started it up and it rolled off the enclosed trailer. Per the sellers spec sheet, I thought it had a g-pipe... but it had a j-pipe and I knew I wouldn't be changing anything.
That was the moment it hit me how different they sound and hopefully this thread will give me some answers. (thanks in advance)
Regarding flow (and the weights of each bypass option), it's all close enough. It's accepted that a bypass might only bring a couple horsepower at best, so leaving 2 horsepower on the table at the benefit to the sound that YOU enjoy is no big deal. Losing 20 pounds behind the bumper verse behind the passenger rear wheel, also no biggie in my book.
Happy to help you out!
Might need a little more clarity on your terminology.
G Pipe = Secondary Muffler Bypass?
J Pipe = Primary Muffler Bypass?
Providing the assumption above is correct - Primary and Secondary mufflers BOTH offer sound attenuation. The Primary is larger and offers more muffling, whereas the Secondary is smaller and muffles less. So by replacing those sections with straight pipe, you can alter the sound accordingly - Primary Muffler Bypass being a more considerable departure from stock than Secondary Muffler Delete.
... There is no real change between those two bypass pipes, they will have the same effect. I agree that it is most likely all personal preference as there is no real engineering change. We have never had a car equipped with the FVD setup, if you have one and are in the area, I encourage you to come by so we can put it on the dyno.
Furthermore, We refer to our Primary muffler bypass as a 'J' Pipe, hence my prior response regarding the differences.
Would love to hear your take on the variability!
JohnK964, i have the same setup. i have tried all possible combinations even bypassed all (cat/primary and secondary). finally settled with this setup, quieter on startup neighbors are happy, gives a deeper rumble on idle at traffic lights. this is just my own preference.
Pardon the ignorance but what do y’all love about your secondary bypass? Does it really sound that good? Anyone got a nicely recorded vid to share? Of course good is subjective but.. I have a hard time understanding the reasoning behind keeping the most restrictive of the 3 components while ditching the least. Opening up the flow took clear precedent over a specific note when it came time for me to choose. If I recall right the primary is also the heaviest single element. Guess I’m just a little confused from a performance standpoint.
No_snivelling (04-12-2021)
#34
Right on, thanks for your answer. I agree - losing 1-2 HP is insignificant if it gets you the sound that you like. I was envisioning a bigger delta there.
Interesting you say the Secondary bypass is more mechanical; would love to hear a clip of your car from inside with the longer pipe.
#35
Yeah, regarding a performance difference we’re totally splitting hairs here. But the sound is different.
I don’t have any way of accurately recording sound to persuade anyone one way or the other. Free rides to anyone that visits!
As much as I like it on cold start, and accelerating through the gears, I really love the in steady throttle in cabin sound from 3,500 -5,000. Super tight mechanical roar.
I think the drilled air box, stiffer motor mounts (and Function First trans 50A insert) all contribute to the NVH sound/experience.
#36
BigSix, what are you running, and what do you like/dislike about it?
#37
My setup is very vanilla - cup pipe only.
Like:
1) The note, especially in the middle of the tach. The classic 911 song that never gets old.
2) Overall volume level seems to be a good compromise.
Dislike: Not a whole lot, but I haven’t heard a ton of setups, so whether or not it’s my favorite is TBD.
luv2race’s vid up there sounds much louder and angrier than my car, presumably from the cat bypass. The main reason I’m hesitant to open it up more is the soft top - the dBs at the wheel go up dramatically with it down and the note gets much deeper. If it’s a little quiet closed, it’s perfect when open. I think for the coupe folks, going the extra step probably balances that scale.
The great thing about these is that it takes a half hour to change stuff around.
Might have to take you up on that visit! Western NC is unreal. Mrs and I stayed in a cabin off the grid in the Pisgah forest a few years back and it was so hard to pack up and leave...
Like:
911Jetta (04-12-2021)
#38
...The main reason I’m hesitant to open it up more is the soft top - the dBs at the wheel go up dramatically with it down and the note gets much deeper. If it’s a little quiet closed, it’s perfect when open. I think for the coupe folks, going the extra step probably balances that scale.
...Might have to take you up on that visit! Western NC is unreal. Mrs and I stayed in a cabin off the grid in the Pisgah forest a few years back and it was so hard to pack up and leave...
#39
John at Fabspeed, I'm sure you are very busy, but would love an update when you have a minute. Many thanks in advance.
#40
Basic Sponsor
Wish I could be of more help!
As I pointed out in my prior response, we do not offer any variations to our secondary muffler bypass. Therefore I cannot give any insight into the performance differences between the two styles.
If anyone has the FVD system and is in our area, feel free to stop by our next Open House and we can throw it on the dyno. Always happy to investigate on behalf of the Rennlist community.
