2nd muffler bypass
2nd muffler bypass
I have a 93 RSA, want to do a 2nd muff bypass. Any recommendations on which brand to get. Fabspeed is $375 there's others for much less. Appreciate any recommendations.
911Jetta (04-09-2021)
Kurttama (04-11-2021)
I’ve had both. One car with a primary bypass for the more traditional cup car sound, and another with a secondary like you are interested in.
Be aware there are different secondary bypass. They differ in length, and that effects the sound/tone. Originally, I wasn’t attracted to the sound of my friend’s cars with the shorter “g-pipe”, too low, woofy (sp?), Harley sounding... then my second car came with a secondary installed... but it sounded different?? Turns out the length has a large effect on the sound. I have what’s called a swan’s neck or “j-pipe”. It has that deep sound, but not Harley or Subi at all. Now I prefer this 100% over a g pipe and has a much better, meaner sound than a primary, which I used to love, but sounds weaker, and tinny in comparison. J pipe all the way. Sounds so good on cold start up, it mean really good for a 964, then really trashes in the cabin at 3,000, gruff at 4000, and starts roaring at 5000, then screams at 6000.
adding a fab speed design cat bypass makes everything 10% louder, but so, so much more mechanical sounding (also gets rid of the heat shield which holds back a lot on mechanical lifter music).
Then drill you air box ($0), for extra sound at 4,000+ and WOT. Checkout some of my posts on it where I explain things better... (on phone now).
The best, cheapest way to get all the sound out of a 964.
John,
Thank you for chiming in, helps having an expert join the conversation. Takes these forum threads to the next level!
Can you speak to my comment and experience above regarding the length of the G-pipe vrs. J-pipe. Forum member have often mentioned their preferences in different threads, but usually is a personal preference, and most people aren't aware that there are secondary options. People default to the G pipe without really knowing why other than they chose that option over a primary bypass, but that's another decision all together.
Why is there a a difference in sound/tone and even volume? Some of that might be obvious, but a more technical explanation would be helpful.
Has Fabspeed tested different variations and came to a conclusion that a G pipe is best?
Was simplicity and cost the final determinate? As, a J pipe construction and the supporting brackets definitely create a more complex product?
Would Fabspeedbe interested in creating a version of a J pipe?
Thanks in advance for answering these questions.
BTW, your cat bypass is very well made and looks like a lot of design/performance consideration went into that, verses just copying a standard design. I've put 3 on various cars over the years.
Basic Sponsor
John,
Might need a little more clarity on your terminology.
G Pipe = Secondary Muffler Bypass?
J Pipe = Primary Muffler Bypass?
Providing the assumption above is correct - Primary and Secondary mufflers BOTH offer sound attenuation. The Primary is larger and offers more muffling, whereas the Secondary is smaller and muffles less. So by replacing those sections with straight pipe, you can alter the sound accordingly - Primary Muffler Bypass being a more considerable departure from stock than Secondary Muffler Delete.
Let me know if this helps!
Cheers, John
denver88carrera (04-11-2021)
Happy to help you out!
Cheers, John
Cheers, John
J pipe is usually this. Also called long g-pipe. Or maybe medium since I think a longer g-pipe has been posted that goes all the way back to the bracket.
911Jetta (04-12-2021)
Basic Sponsor
g-pipe is right.
Want to make sure I give you the highest quality recommendation!
G pipe is 2nd muffler bypass short, its the shape of a G
J pipe is 2nd muffler bypass long, its in the shape of a J
Kinda thought a specialist might have known this.........................
Basic Sponsor
There is no real change between those two bypass pipes, they will have the same effect. I agree that it is most likely all personal preference as there is no real engineering change. We have never had a car equipped with the FVD setup, if you have one and are in the area, I encourage you to come by so we can put it on the dyno.
Furthermore, We refer to our Primary muffler bypass as a 'J' Pipe, hence my prior response regarding the differences.
Would love to hear your take on the variability!
The following 2 users liked this post by mperez:
911Jetta (04-12-2021),
Fabspeed Motorsport (04-12-2021)
