MAF kit from FVD (lb2)
You should of done a follow up video with your concerns, so that potential buyers have all the info
I've been looking for a replacement for the barn door AFM for ages!
But there just doesn't seem to be anything plug and play off the shelf...
I'm not saying the MAF is bad.
But I do feel disappointed that FVD shows no concern about this issue. In the end, my car was better before, except when the pedal is floored.
As I recall there was only one pin in the Motronic box needing to be cut and a jumper wire used. I took mine to an electronics shop and had it done, with the instruction that it be reversible. It’s unfortunate that you received no support from FVD. In my case I had terrific help and felt as though they wanted to do all they could to get it working properly. I came away only disappointed with the MAF not working for me but with a good view of FVD.
My recommendation for anyone looking at a MAF kit in general to be thorough in researching and talk to other users of the particular supplier. Also, get a guarantee of being able to return the parts if it can’t be made to work properly. And don’t do anything to your Motronic that can’t be reversed.
In my opinion there is a BIG difference in customer service between Germany and the USA.
I had a few problems with parts / orders and the customer service was really bad.
Now I only do business with them if I don't find the parts somewhere else or if they are a lot cheaper (rare).
Peteinjp (05-05-2021)
The standard AFM is already back in the car. As soon as I get my motronic back, I will test and see if everything is ok !
I bought one of these kits second hand here in Houston:
http://www.vitesseracing.com/html/91..._air_flow.html
It has provided all of the benefits mentioned above without any of the negatives. Throttle response is much improved and drivability remained unchanged. Individual results may very but I've been very impressed with the Vitesse kit. I've had it on the car several years now.
Vitesse offers a true plug and play MAF kit for the 964.
The Vitesse MAF kit was designed, developed, sold and supported by us. Based on actual experience, the Vitesse kit offers great drivability, reliability and performance. I encourage you to verify this with any of our customers and users.
Feel free to contact me directly if you have any questions.
