MAF kit from FVD (lb2)
Hi guys !
I recently purchased a MAF kit with chip and air filter for my1992 C2 cab tiptronic. It is said to bring a better throttle response and more torque, this is what I'm looking for with the tiptronic transmission.
The kit is from FVD Germany and the modification on the motronic was made in their factory.
The kit fits perfectly on the car, easy installation in less than 30 minutes.
But when it comes to the running of the car, it is a complete disaster. The idle is rough, hunting, going from 800 to 1000rev/min and back in a terrible noise.
The car has now backfires downhill, even when idling, and is a Real pain to drive smoothly. When cruising at low RPM, the engine makes a horrible vibration noise and runs terrible.
Do someone have a good experience with this kit or should I just send it back ?
thanks !
Alexis
thanks !
Alexis
I bought their MAF kit last year, the instructions for the US are different than for Europe. It was an easy install and the car ran great, sharper throttle response with more power you could feel. My problem occurred off-throttle. Once the car warmed up, when I closed the throttle approaching a stop sign or running downhill, the fuel would shut off and when reapplying the throttle it would take two-to-three seconds to cough to life again. To FVDs credit, the owner, *****, and an engineer got on the phone with me four times to try and solve the problem. I had to take it to my mechanic to test and check things beyond my scope. Finally, after not finding a solution to the off-throttle problem I returned the parts for a refund. Apparently a 964 with a MAF conversion, regardless of manufacturer, may have the off-throttle problem I encountered. On-throttle the car was a blast and when I put my OEM back on, though it ran perfectly, it wasn't as sharp, fast, or fun to drive. I'm currently having a Motec Kit from Rasant installed because I couldn't get how well the car ran on-throttle with the MAF kit out of my head.
Though my problem was different than yours, I would call FVD and see if they will help you solve your problem, let them know upfront you will return the kit if the drivability problems can't be solved and get them to agree to it. Otherwise, send it back now.
Thank you for your reply.
I called FVD, they told me this must be a problem on the vacuum system. According to the guy on the phone, a MAF is more sensitive to vacuum leaks than the standard AFM.
But I never noticed any trouble before fitting this kit... What could be the symptoms ?
Oh, and last but not least, he told me that they don't take this product back !
PAOLOP (05-05-2021)
I had similar issues.
Initial impressions of the MAF were highly favourable with increased throttle response and better drivability (so much so that I made a video about it). Performance on throttle was seemingly particularly improved.
But the more I drove the car, the more I began to experience. Cold starts were awful with the car requiring a few cranks to get going and warm starts had the car sounding really "cammy" like a race car for the first 60-90 seconds. The car developed a hesitation on downhill sections off-throttle.
We reached out to FVD to work with them on solutions but their answer was always the same - had nothing to do with the MAF or the chip. We looked at every alternative they suggested could be the cause, including vacuum system as suggested to you @anteuzer but found no issues. I'm not going to say unequivocally that the FVD MAF was the cause of the issues, as I don't believe that'd be fair. However, FVD's unwillingness to even entertain the notion that it was somehow related to the MAF and chip was the biggest disappointment.
Thank you for your reply. This is the feeling I have, they do not put into question their kit, even if I had no trouble before it was installed.
Did you manage to have your motronic and chip back to how it was before ? I know they made some changes inside, and I hope they can reverse them.
I still have the original intake, but my concern is about the dme. I hope that FVD can reverse what they dis inside the motronic.
Moreover, when I got the package, I noticed that they forgot to give me the original chip.
My concern is the car is japanese (with two probes on the exhaust), so I don't know if a random 964 C2 tiptronic chip will work.
Yes, they offered to do it so that no mistake is made. They told me they had to jumper something inside, but I don't know what.
Great idea, I can contact him, thank you !
I installed mine and car works really bad after installation. End up that HAL-sensor was broken. When fixed that, idle etc. started works as it should.
Yes they do. You have cut two pin inside of box and make jumper between them. I don't think system works properly without that modification.
Given what I am experiencing, I would advise you to stick with the AFM... But it's only my opinion.
