instrument cluster light issue
Hello all,
I recently decided to replace the little 12v bulbs for my centre console to get them working again. When removing the circuit boards I also unattached an aftermarket air con switch sits in my centre console (pictured).I have reassembled everything except the aftermarket switch, unfortunately when checking I now have no working centre console lights (with new bulbs) and the back light for my gauges has also gone :-( Other interior lights are working.
Pictured are the wires that I believe were attached to the aftermarket switch, I have no idea which wire attached to the switch (stupidly did not take a pic before detaching) but presume that this is causing the issue of no lights on my console or gauges.
If anybody has any suggestions on how to remedy this issue and get my centre console and dahsboard gauges lit up again I would be grateful!
Best,
Tim
Best,
Tim
Did you disconnect the battery before getting into the console? If not check for any blown fuses in the fuse panel.
If no blown fuses, get your VOM out and check your 4 wires, Brown is usually ground so check for conitnuity to a good ground. The others are possibly battery, or switched power from the ignition switch (turn the ignition key to "accessory" position, and measure for voltage), and then the device it powers (A/C?)
Is this switch taking a spot of one of the 3 usual switches on the console just above the rotary switch for the spoiler?
Is there a part number/ manufacture/ logo on the body of the switch?
I am going to check my soldering to the upper console board as suspect this might be the problem here!
Sorted! Turned out it was my poor soldering as I had added too much and joined the terminals! Removed some and hey presto, we have lights after some 12 years without 🙂
The following 2 users liked this post by timrichardson:
cbracerx (06-23-2022),
mark lintott (06-18-2022)
