My Engine Removal / Refresh Thread
#106
Good call!
You will sleep better = happy! The engine and chassis look awesome
revolve40 (02-16-2023)
#108
The motor and the car look awesome! Can't wait to get your thoughts once you have driven it for a bit.
revolve40 (03-13-2023)
#109
Thanks! Yes - fiberglass. From DP Motorsport. Impressed with the fit and finish for the price (some trimming required but not much). The goal is to save as much weight in the rear as possible for a street car, so fiberglass vs. sheet metal makes sense here. Did not opt for the (very expensive) fiberglass shroud as there is very little, if any, weight savings compared to the stock plastic part.
That looks super clean. I might have missed it - which headers and muffler do you have on there?
#110
I have a TT Exhaust equal-length system. I have heater boxes as well but going to run without for now.
Jaime_911 (03-13-2023)
#112
Air filter frame
Looks like it's the Fabspeed one, and it looks pretty sweet.....https://www.fabspeed.com/porsche-964...rmance-airbox/
@revolve40 - your build continues to inspire me. We've chatted on IG about the TT setup, and I ended up purchasing your old Fister/Cup setup. Really appreciate all the help answering questions and posting up the details of your build. Good luck getting it on the road soon!
#113
#114
You might have mentioned it - but looksl ike you're sticking with motronic? I see the trap door on there - any interest in going with a different setup? I've heard (and I believe after holding one in my hand) that it is very restrictive.
#115
It has been discussed in depth on this forum whether the stock AFM is restrictive or not. The camp I subscribe to believes that while an upgrade may increase responsiveness, the power gains aren’t obviously clear.
#117
Nice work! Do you have what all you did documented somewhere? I’m trying to get to that point myself.
#120
FVD RS-copy bucket seats
AppBiz Sliverknit RS carpet with rear seat and sound deadening removal
Airbag removal
Renown steering wheel
RS window washer reservoir
Manual aero mirrors
RS door cards
RS rear glass / defrost delete
Antigravity lightweight battery
E88 wheels
Numeric shifter (allows for forward shifter rod delete)
Lightweight flywheel
AC delete
Heater box delete
Header system with no cat and light primary muffler
Power steering delete
Sound pad delete
Plastic intake manifold conversion
Fiberglass engine tins
Rear bumper heat shield delete
Lower dash delete
FVD RS-copy aluminum hood
RS intake ducts (fog delete)
I’m likely forgetting many minor weight-saving changes that all add up over time, but I think this is most of it.
