WTB sport cat for 964
I'm running a Dansk Cat Bypass with a cup pipe, combined with a SW Chip. You can definitely hear a difference at startup/idle and under acceleration but if you're just cruising it's really not much more noticeable. I just had a cop doing an on-ramp seatbelt check tell me to slow down because I was going too fast (I was under the speed limit) so I'm sure that was just his way of telling me it sounded awesome. I installed the bypass tuned SW Chip before I installed the bypass, and it definitely feels better afterwards. I like the Dansk because you can retain all the heatshields for a factory look.
The exhaust smell is definitely a thing though..
Yes, many on here have confirmed the smell being noticeable with a cat bypass. I noticed it the moment I swapped out my OEM cat for a gutted cat. Now, even with the garage door open, I cannot run the engine for more than a few minutes, but while driving it is mainly the guy behind you that suffers.
Ha, there’s definitely a bit of smell that goes with a cat bypass, or delete. It smells like, victory.
mystert (10-30-2022)
Closed loop injection constantly cycles between 14.x:1 to 5.x:1 at idle. So you get excess HC and CO when on the rich cycle and excess NOx when it cycles lean. Not sure if that’s the reason for the extra stink compared to older systems but could explain it. The 964 also dips excessively rich on wot.
I would be surprised if a sport cat robbed more 5hp over a bypass even on a modified motor. Foxman knows I’m a hippie but I strongly advocate a sport cat.
This has come up a zillion times. No reason to spend silly dollars- https://rennlist.com/forums/964-foru...l#post18358777
The location info next to my name should help answer your question? The OP is in Texas. This is a worldwide forum. There aren’t any CARB compliant CA 964 cat options that I’m aware of, but it sounds like you’re not looking for sport cat options anyway? Was your CA-specific post directed toward me? I think I miss the reasoning.
just bought this from FVD today. couldn't resist the price.
looking forward to hearing how this, the cup pipe, and fister muffler sound together.
I am curious, what does a classic short wheel base Porsche 911 from the 60’s-70’s smell like?? They have rich running carburetors and zero emissions controls/catalytic converters. A cat deleted 964 with modern electronic fuel injection compared to those classics is night and day, and even without a catalyst it runs much much cleaner. I could understand those classics smelling “obnoxious” but who in their right mind describes a 1969 911 that way? Maybe a Tesla fanboy but not a Rennlist Porsche enthusiast.
I still plan on installing the rennline unit on my 964 - its 10% off currently as an early black friday sale.
If you want to add some horse power, and still be kind to the environment, DP Motorsports caries a 100 cell catalyst.
Foxman (11-26-2022)
